is this normal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aspec101 »</TD></TR><TR><TD CLASS="quote">do a leak down test, but I would supsect rings or valve stem seals or a combo of both.The black smoke is from running rich, but I see a hint of blue also which is oil.</TD></TR></TABLE>
i agree. i think you might be running a bit rich but you look like your buring some oil. does when driving you car does it all the way through the rpm range? or just when you first get on it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">i agree. i think you might be running a bit rich but you look like your buring some oil. does when driving you car does it all the way through the rpm range? or just when you first get on it?</TD></TR></TABLE>
just when i get on it. nothing comes out if i drive normal
i did a compression test and it showed 210-215 all the way accross all cylinders
del sol1658
Mar 27, 2007 01:02 PM
