crooked steering wheel
Old Apr 27, 2006 | 09:23 AM
MobRacing2's Avatar
Default crooked steering wheel
my steering wheel sits about a quarter turn off center, and i recently replaced my steering rack... of course i know that the problem is that i didnt get the steering shaft and the pinion gear lined up correctly.does anybody know a way to "adjust it with out taking those parts off? or if you do have to take them off perhaps any easy way to line it up??
thanks for the help
Old Apr 27, 2006 | 09:38 AM
AutoXer's Avatar
Default Re: crooked steering wheel (MobRacing2)
You need an alignment. They will set the toe with the steering wheel straight.
Old Apr 27, 2006 | 09:51 AM
Average Al's Avatar
get an alignment
the adjustment is the tie rod.
u can always take off the steering wheel and move it over a notch but thats ghetto
Old Apr 27, 2006 | 10:21 AM
wheelmanbg's Avatar
Default Re: (Average Al)
I don't think alignment will fix 1/4 turn
Old Apr 27, 2006 | 10:32 AM
SHG_Beans's Avatar
daaammnn a quarter turn? just do what you didnt do correctly to begin with. Alignment i highly doubt will correct a 1/4 turn, thats quite a bit.
Old Apr 27, 2006 | 10:36 AM
MobRacing2's Avatar
Default Re: (ek gripper)
yeah well how do you line it up right? thats my question. i had the wheels straight and the steering wheel straight. how do i do it right??
Old Apr 27, 2006 | 10:52 AM
Slopoke's Avatar
Default Re: (MobRacing2)
I would suggest disconnecting the rack and pinion and recentering everything.
If you just pull your steering wheel off an stick it back on straight, you have the possibility of breaking the clock spring and disabling your airbag.
Old Apr 27, 2006 | 11:07 AM
MobRacing2's Avatar
Default Re: (Slopoke)
no air bag.. aftermarket wheel.
but let me run this by you people. what if i recenter it. i imagine that it might not be exact. should i get it as close as i can then get it alligned?? does this sound right. because i am thinking that there is no way that car that i got the rack from had the exact same alignment adjustment setup as mine..
Old Apr 27, 2006 | 11:29 AM
tallyturbo's Avatar
Default Re: (wheelmanbg)
alright here is what to do. look above your gas pedal and remove the plastic covering the steering rack. it should be held on by 2 clips. then you will see the knuckle that connects the two shafts. take a 10mm and undo the two bolts that hold it on. then you are going to have to wiggle the knuckle up until it comes off the bottom shaft. your steering wheel should fall loose. straighten the wheel add the kunckle back on and tighten the bolts.
a tip:
since you are going to have to turn your wheel to get the bolts off that hold on the kunckle your wheels arnt going to be straight. to get the best results undo the bolts then drive the car 10 feet. this assures that the tires are straight and after that take the knuckle loose. and the recenter it. this should almost make it perfectly straight.
Old Apr 27, 2006 | 12:17 PM
5 Skware's Avatar
I missed the boat
Default Re: (tallyturbo)
If you have an aftermarket wheel was it crooked to begin with? If so the rack may not have anything to do with it.
Old Apr 27, 2006 | 12:32 PM
MobRacing2's Avatar
Default Re: (5 Skware)
nope it was straight. so i should just try to realign it. then get an allignment??
Old Apr 27, 2006 | 12:40 PM
tallyturbo's Avatar
you probably just put the wheel on crooked. doing what i said will still fix the problem and it is easy to do. you dont even need an alignment.
Old Apr 27, 2006 | 12:45 PM
MobRacing2's Avatar
ok man i never moved the wheel..... i replaced the power steering rack with a non power steeringing one.
what i am asking is: is there a special way to line up the teeth on the steering shaft... or do you just do it by looks??
Old Apr 27, 2006 | 12:51 PM
SHG_Beans's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">alright here is what to do. look above your gas pedal and remove the plastic covering the steering rack. it should be held on by 2 clips. then you will see the knuckle that connects the two shafts. take a 10mm and undo the two bolts that hold it on. then you are going to have to wiggle the knuckle up until it comes off the bottom shaft. your steering wheel should fall loose. straighten the wheel add the kunckle back on and tighten the bolts.
a tip:
since you are going to have to turn your wheel to get the bolts off that hold on the kunckle your wheels arnt going to be straight. to get the best results undo the bolts then drive the car 10 feet. this assures that the tires are straight and after that take the knuckle loose. and the recenter it. this should almost make it perfectly straight.</TD></TR></TABLE>
What he said, do that and you're set. Its quite easy.
Old Apr 27, 2006 | 12:58 PM
tallyturbo's Avatar
chill out im just trying to help. i garentee if you do what i said that will fix your problem.
Old Apr 27, 2006 | 01:13 PM
MobRacing2's Avatar
Default Re: crooked steering wheel (tallyturbo)
ok so let me run this past you to see if i am comprehending it.. i take off the knuckle from the steering rack. i straighten the tires as best as i can then straighten the steering wheel. reconnect the knuckle. drive or in my case push (cause no motor)car 10 feet to see if wheel stays straight. if not dissconnect knuckle and straighten wheel..
does that sound about right??
Old Apr 27, 2006 | 01:22 PM
SHG_Beans's Avatar
close, i think what tallyturbo was saying was that you have to turn the wheel to loosen the bolts before you disconnect the knuckle, so loosen them first, drive the car 10 ft, THEN remove it and straighten your wheel and refasten.
Old Apr 27, 2006 | 01:28 PM
MobRacing2's Avatar
i dont see why you would have to turn the wheel to loosen anything. you take the bolts out and take pinion gear out of the knuckle..
Old Apr 27, 2006 | 03:32 PM
MobRacing2's Avatar
bump
Old Apr 27, 2006 | 03:59 PM
spock_rocker's Avatar
memoryFAB.com representative
when i put on my sparco wheel it was a little off, i learned to live with it. i got an alignment, found out i had a broken tie rod.. the combo of the two straightened the wheel!
Old Apr 27, 2006 | 05:22 PM
Syndacate's Avatar
just take it to get aligned, they can straighten the wheel's to align with the wheel np &gt;.&lt;
they usually have a piece that they put on teh steering wheel that keeps it centered, then they adjust the tie rod so it's straight and 4 wheel align it, that's what they do at tire discount, by me, anyways :-\
Old Apr 27, 2006 | 05:42 PM
tallyturbo's Avatar
Default Re: (spock_rocker)
the reason you have to turn the wheel is because of where the bolts are. trust me once you see it you will be wondering why you are asking so many questions. undo the bolts. bush you car 10 ft to make sure the tires are straight. unloose the knuckle, straight the wheel and reconect. after its reconected add the bolts back and voolia
Old Apr 29, 2006 | 09:19 PM
SHG_Beans's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MobRacing2 &raquo;</TD></TR><TR><TD CLASS="quote">i dont see why you would have to turn the wheel to loosen anything. you take the bolts out and take pinion gear out of the knuckle..</TD></TR></TABLE>
I think to get access to the bolts on the knuckle you have to turn the wheel.
SHG_Beans's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">the reason you have to turn the wheel is because of where the bolts are. trust me once you see it you will be wondering why you are asking so many questions. undo the bolts. bush you car 10 ft to make sure the tires are straight. unloose the knuckle, straight the wheel and reconect. after its reconected add the bolts back and voolia</TD></TR></TABLE>
Yeah seriously, just f-in try it already god damnit! itll fix the problem!
civic4life8045
Jun 5, 2013 03:16 PM
civic4life8045
18
Jun 5, 2013 09:10 AM
Eibach95Civic
Sep 20, 2007 07:44 AM
kento
Jul 5, 2001 04:56 PM
