D16Y5 to B18B swap - Will o2 sensor harness work?
I have a 97 HX and I will be doing a B18B OBDI Turbo Swap very soon. Since the factory harness is for a wideband O2 sensor, will it present any problems when I swap the motor and use a narrowband O2 on the B18? I will be using an OBDI ECU with a OBDIIa-OBDI jumper harness. Thanks.
A 4-wire O2 sensor isn't going to plug into a 5-wire WBO2 sensor connector, if that's what you mean. So yeah, it'll be a problem until you fix it by either using another OBD2a harness that uses a 4-wire O2 sensor or by doing some cutting/soldering to your existing harness.
Hey man Glad to see your project coming along. Hopefully I can get the ***** to build my on motor if I ever decide what to do. Best of luck to you.
[Ennis_D]
Southeast (Sales)
May 29, 2011 06:59 PM
exare250
Nov 24, 2004 10:59 AM
