Need help! will 91' auto starter work with 91 5speed tranny and d16z6?
Iam doing an auto-to-manual+d16z6 swap in my 91crx and was wondering if I could use the automatic starter off my old d15b with the l3tranny/d16z6?
Modified by wfocrx at 2:16 PM 5/1/2006
Modified by wfocrx at 2:17 PM 5/1/2006
This post should be moved here: https://honda-tech.com/zeroforum?id=27
But to answer your question, yes it will work. The only thing you will have to do is bypass the clutch safety switch. That is what will keep you from starting your car.
why would a question about using my starter that I used on my automatic d15b2 with my new manual l3 tranny setup be in audio/security?
Does my automatic car have a clutch safety switch?
