Suspension & Brakes Theory, alignment, spring rates....
Rear toe adjustment question
Old Apr 26, 2006 | 08:04 PM
j spec's Avatar
Default Rear toe adjustment question
ok just had a full allingment done and for some reason the toe is out on my passenger side rear. the adjustment arm is all the way in. also on the driver side the arm is about in the middle but the toe on that side is fine. its a 95cx hatch and my rear disks are off a 93 si. just wandering if i just need to buy a adjustable toe arm or should i check something else first. im just hoping the whole rear trailing arm isn't bent. i hadn't had a chance to inspect it any after i left the alingment shop. just wandering if anyone has had a similar problem. thanks
Old Apr 26, 2006 | 08:29 PM
PIC Performance's Avatar
Default Re: Rear toe adjustment question (roma's GSReg6)
Yup, had this problem over the weekend on an EF, and on my own DB8 as well. No visible damage, but something was sure as hell bent, as we ran out of adjustment before we could zero out toe in the rear. An adjustable compensator arm will only mask the problem.
Old Apr 26, 2006 | 08:52 PM
j spec's Avatar
Default Re: Rear toe adjustment question (PIC Performance)
thanks. after further inspection i guess i'll start looking for another rear trailing arm
brownsEF
Feb 27, 2010 07:01 PM
circapunk
Suspension & Brakes
Apr 22, 2009 01:15 PM
PRoJecTSLeePaLoT
Mar 22, 2007 10:35 AM
j spec
Apr 28, 2006 08:56 PM
j spec
Apr 25, 2006 04:17 PM
