tell me what you think
i have a b18a1 block with lsrods and gsr pistons it will be lsvtec with a b16 head with gsr cams and some aftermarket cam gears i have a 4to1 header 2.5 exhaust no cat 8.8 lb flywheel type r clutch and pressureplate type r water and oil pump skunk 2 chipped ecu. and using a 2layer head gasket... in a 92 hatch cx version the light one....i might decide to spray a 75 shot on it tell me what yall think this setup will make in hp w/o spray if it is tuned and what you think it will run in 1/4 with and w/o spray thanks alot
rfuentes29
Sep 17, 2005 04:27 PM
