H22a(jdm) vs H22a(usdm)
h22a1(4thgen)usdm
- sand cast, close deck
-main bearing is 50mm
-compression 10.0:1
-190hp/158trq
-obd1
h22a4(5thgen)usdm
-die cast, open deck
-main bearing is 55mm
-compression 10.6:1
-200hp/156trq
-obd2
jdm h22a 96-00
same as a4 but diff compression,hp, main bearing, which is already posted above
-compression 10.0:1
-190hp/158trq
-obd1
h22a4(5thgen)usdm
-compression 10.6:1
-200hp/156trq
-obd2
jdm h22a 96-00
there the same. do the tensioner conversion, swap fuel rails injectors and FPR, splice yellow external coil wire into black/yellow internal, change ecus, wire your 4 wires and be done with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UpShift »</TD></TR><TR><TD CLASS="quote">you mean swap the h23 feul rail/injectors ect. to the h22 right? wouldnt that come with the engine?</TD></TR></TABLE>
i dont ahve a clue what the original reply meant, but you would swap over your fuel rial since it matches the fuel lines on your car. you need to use the h22 injectors.
vietdragontekx
Mar 15, 2007 07:57 AM
