headlight moisture
Old Apr 26, 2006 | 06:00 PM
d1nki's Avatar
Default headlight moisture
how do i remove the headlight moisture so i can make my own black housing? I searched already and nothing came up, only one with no answer. Any advice can help.
Old Apr 26, 2006 | 06:05 PM
E46Kid's Avatar
1. remove headlight from car
2. put it in the oven. for 350 degree 4 mins tops
3. open it removing the silicone with a butter nipe or flathead
4. clean moistore, paint the housing
5. resilicone it and put it back in the oven
6. put it back on the car
Old Apr 26, 2006 | 06:06 PM
Tyler01's Avatar
Default Re: headlight moisture (d1nki)
If your talking about wanting to remove condinsation from your headlights, Take a heat gun go move it slowley back and forth. Like a 4 inches away from the headlight so you dont melt the. Also you can stick a air hose on the back of the headlight to keep the air moving in the inside while you use the heat gun.
Old Apr 26, 2006 | 08:14 PM
d1nki's Avatar
alright thanks
Old Apr 27, 2006 | 06:08 AM
Newkdog's Avatar
I miss Andrea.
Mine shows up and rand0mly goes away
Old Apr 27, 2006 | 06:48 AM
reebs's Avatar
i read 200 degrees for 10-12 min
Old Apr 27, 2006 | 08:26 AM
iam7head's Avatar
Default Re: (reebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reebs &raquo;</TD></TR><TR><TD CLASS="quote">i read 200 degrees for 10-12 min</TD></TR></TABLE>
different oven have different heating rate, don't go by the number alone, keep close watch
there's little vents in the back, it's usually have a black rubber elbow, make sure you have that thing pointing down.
8dxhatchy8
17
Feb 17, 2009 07:16 PM
stevew84
Apr 10, 2008 09:23 AM
Turbo_honda
Aug 3, 2006 02:18 PM
HaRrYbOy
Honda Motorcycles
Jan 2, 2006 09:45 PM
petrv
May 6, 2003 10:11 PM
