Front lower balljoint replacement?
Old Apr 26, 2006 | 05:01 PM
theelemental's Avatar
Default Front lower balljoint replacement?
Ok, I've tried searching on this one, and haven't really figured out what I want to know...
I have a 1989 CRX hf w/ b16a swap
Today I replaced my driver-side axle for the first time, and discovered that the lower ball joint bushing was destroyed, possibly leading to the cracking of my axle. I can move the bolt extremely easily by hand (once the castle nut is off). how do I get the balljoint out, and how do I re-install? do I have to remove the knuckle, or what? seems like if I can hammer up from the bottom of it I may be able to pop it out? the rubber is all destroyed...
last thing... could someone post a pic telling me the terminology regarding the ball joint? I'm still a little confused about the boot/bushing, etc.
Thanks
Matt
Old Apr 26, 2006 | 05:05 PM
nwf_snake's Avatar
Default Re: Front lower balljoint replacement? (theelemental)
It normally has to be pressed out using a special c-clamp looking tool with the appropriate adapters, and then pressed back in using other adapters. I think you can do it on the car if you can get it high enough off the ground and have the correct tools. Off the car, you can use a big vise with the same adapters for removal and installation. At least that is what the Helms and Haynes manuals say/show. Good luck, I will be doing mine within the next month or so.
Old Apr 26, 2006 | 05:06 PM
d16vtecx's Avatar
try using a puller for the ball joint
Old Apr 26, 2006 | 05:14 PM
Default Re: Front lower balljoint replacement? (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx &raquo;</TD></TR><TR><TD CLASS="quote">try using a puller for the ball joint</TD></TR></TABLE>
What exactly is a puller?
ANOTHER QUESTION:
from the lower control arm, there is a straight metal bar that leads toward the bumper/frame. I noticed that there was about 1cm of space between the LCA and this bar, since the bolt was not all the way snugged up. I tried tightening it but it was very hard to move. What is this, and should I keep trying to tighten it all the way?
Old Apr 26, 2006 | 06:47 PM
bump for more info
Old Apr 26, 2006 | 07:03 PM
rsca_crx's Avatar
that is your radius rod, and it controlls forward/aft movement of the front suspension assembly (well, it keeps it from happening)- so yeah, it is important.
there should be no gap between the rod and the lca. perhaps you have the wrong bolts in it, or maybe it is just a bit rusty. i'd pull the bolts out, chase it with a tap and run a die over the bolt, and see if things get better. comparing it to the other side is a good idea too.
either way, don't ignore it.
Old Apr 26, 2006 | 07:08 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theelemental &raquo;</TD></TR><TR><TD CLASS="quote">
What exactly is a puller?</TD></TR></TABLE>
http://www.reesetiresupply.com...=4650
puller might work if you can find a socket to put over the ball joint threads. use the puller as a pusher.
ANOTHER QUESTION:
from the lower control arm, there is a straight metal bar that leads toward the bumper/frame. I noticed that there was about 1cm of space between the LCA and this bar, since the bolt was not all the way snugged up. I tried tightening it but it was very hard to move. What is this, and should I keep trying to tighten it all the way?</TD></TR></TABLE>
the long bar is called the radius rod. I'd pull the bolt out and check the threads before i continued. on my car the knuckle has to be removed and the axle must be lifted up to pull that bolt out.
White_EG1
22
May 21, 2018 10:20 AM
C_Rock77
Aug 27, 2008 11:19 AM
LaterApex
Suspension & Brakes
Oct 21, 2005 09:33 PM
91zSi
30
Aug 4, 2005 04:09 PM
munscher
Jun 16, 2003 06:34 PM
