Honda Prelude Techs PLEASE help!
Old Apr 26, 2006 | 04:56 PM
SPRLude's Avatar
Default (h22 swap) PLEASE help!
i have a 1992 h23a and want to put he h22 in, can someone please give me a list of all the parts that NEED to be swapped out of the h23 in DETAIL ie. distributor, alternator... i need to know this because the junk yard i went to didnt know what the to give me and the engine/parts was in peices (not completely the head and block were together), i need to know what parts are interchangable and what are not. so if anyone can PLEASE give me a "things to buy" list i would GREATLY APPRECIATE it... and does anyone know if the h22 engine will run without the p13 installed yet?
THANK YOU in advance
Modified by UpShift at 6:11 PM 4/26/2006
Old Apr 26, 2006 | 08:54 PM
chrish22a's Avatar
B A N N E D
Default Re: (h22 swap) PLEASE help! (UpShift)
you really just need to wire the vtec and yes you can use the p14 ecu you just won't have vtec i drove mine for about 3months before i got my p13
Old Apr 26, 2006 | 09:39 PM
SPRLude's Avatar
Default Re: (h22 swap) PLEASE help! (chrish22a)
do you know if the alternator, starter, ect... are all interchangeable...could i use the ones from the h23
Old Apr 26, 2006 | 09:59 PM
BB6racer's Avatar
the starter should work fine. wire harness should work fine as long as you get a motor with the same obd as your car. alternator might need a different belt (same with PS and AC, but i'm not sure). also, check this out, it will tell you how to wire vtec:
https://honda-tech.com/zerothread?id=1004852
Old Apr 26, 2006 | 10:21 PM
SPRLude's Avatar
Default Re: (BB6racer)
oh thanks. yea wireing vtec doesnt sound that hard
Old Apr 26, 2006 | 10:23 PM
SPRLude's Avatar
the timing belts are going to be different right?
Old Apr 26, 2006 | 10:31 PM
95greenlude's Avatar
how many threads are you going to make about swapping in an H22.....there is a red button at the top right hand corner of the page, as well as a FAQ thread at the top of the prelude forum
My93Cb7
Aug 25, 2009 08:28 AM
integra_ls_2dr
Jan 22, 2009 08:15 AM
LostMkiv
Feb 19, 2008 12:23 PM
LostMkiv
Feb 18, 2008 06:13 PM
LostMkiv
Jan 17, 2008 07:01 AM
