question my tact no working
Old Apr 26, 2006 | 04:38 PM
TheAccordGuy's Avatar
Default question my tact no working
I'm using a b16 ignition coil and igniter with an accord ECU on my JDM h22a would this set up cause my tact no to work. I believe the coil is responsible for the tact readings.
Old Apr 26, 2006 | 05:52 PM
SlimBB4's Avatar
Default Re: question my tact no working (TheAccordGuy)
this happened to a friend of mine too, ended up being the "speed sensor"?
_zAC
Old Apr 27, 2006 | 04:59 AM
Well the speedometer still works so I figured it was not the speed sensor.
Old Apr 27, 2006 | 05:20 AM
syntax.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">I'm using a b16 ignition coil and igniter with an accord ECU on my JDM h22a would this set up cause my tact no to work. I believe the coil is responsible for the tact readings.</TD></TR></TABLE>
wow. do you know what ecu you are using? accords came with a few different engine choices. the ignitor is in the distributer, does that mean youre using a b16 distributer as well?
Old Apr 27, 2006 | 06:57 AM
v4lu3s's Avatar
RTFM
usually loss of tact comes along with people not wanting to be around you as well. are you suffering from that problem too?
The_Sober's Avatar
Default Re: question my tact no working (sYn)
tactless...that's funny
Old Apr 28, 2006 | 04:09 PM
Yes im using a b16 ignitor sorry for the type-o with the word tact should have been tach.
Old Apr 30, 2006 | 07:40 PM
HatchSpeeD's Avatar
He's using the correct ecu now (P13) & still no tach. Also for some reason the turn signals went out. Checked the fuse but I guess we'll get more in depth later. Any ideas?
Can a speed sensor still be if your speedo still works..?
THEhomelessONE
Other Make Vehicles
26
May 6, 2009 09:57 PM
ShortbusEK
May 23, 2008 07:05 PM
usdmEHboy
Feb 14, 2007 05:58 PM
WNYAccordLX
Mar 22, 2003 06:12 AM
LoudAccord
Nov 13, 2001 03:07 PM
