H22 or H23?
Ok my engine is about to hit 90k miles and i wanted to get a new engine for my car and pull the current one for a project car, but my question is should i go with an H22 or an H23???
It depends on what road you want to go down. If you want boost then the h23 is the best for it. The h22 can be boosted but it would require more attention to the motor. If you want all motor then i would go with the JDM h22. They are about the same except for VTEC. This is what i did, although going all motor is very expensive if you want to see big numbers. With the h23 you can buy a good turbo setup for around 4k. With a little work to the motor you can call it a day.
this topic has been covered...a lot. Check out this link. It will have every bit of information you'll need.
https://honda-tech.com/zerothread/689805
Lol not only is it hard to find, it is $$$ more than vanilla h22a, but then you do get alot of parts you can sell as a premium eg. cams,pistons ect. Check out hmotors, think they still have a type s for sale for about 4200 or so. Since the route to N.A perfection is long and very $$$, I would go with a good vanilla h22a complete swap for about 2,200-2,400 and use the extra 2k for essentials like RMF,SMSP,Hytech,DTR header, EuroR intake manifold or ITB's, Crower valvetrain and things like these.
lol your hitting 90k and wanting a motor swap. im at 278k and im doing my swap. you got plenty of miles left in her.
as for which you should get id go with h23 and boost the hell out of it.
Is that your 5th gen in the picture? If so try to get a H23A VTEC (Bluetop), it's OBD2 and bolts directly into your car. It's more expensive than a H22A, and less expensive than a Type-S. But more than all, rarer than both.
