What is code
Old Apr 26, 2006 | 02:32 PM
jojo69's Avatar
Default What is code
i have a 93 honda accord
check engine code is 42 - any idea what it is?
Old Apr 26, 2006 | 05:19 PM
hondadude's Avatar
Default Re: What is code (jojo69)
count the flashes again, no such code is in the listings; but thanks for trying to provide good info so we can help you better. Any other noticeable driving problems?
Old Apr 26, 2006 | 07:46 PM
accord-pro's Avatar
4-2?? abs code ??
Old Apr 26, 2006 | 09:01 PM
93acclude's Avatar
Default Re: What is code (accord-pro)
there is no specific listing for an 4-2, just 4-1 through 4-8, all abs codes. you probably have a bad wheel speed sensor. Use a multimeter and check the resistance between the terminals of each sensor. front should be between 700-1100 ohms, and the rear should be between 1000-1600 ohms. If one is not within that range, replace it.
Old Apr 26, 2006 | 09:15 PM
philadd's Avatar
Default Re: What is code (93acclude)
4-2 = front left wheel lock... whatever that means.
Old Apr 26, 2006 | 10:09 PM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93acclude &raquo;</TD></TR><TR><TD CLASS="quote">there is no specific listing for an 4-2, just 4-1 through 4-8, all abs codes. you probably have a bad wheel speed sensor. Use a multimeter and check the resistance between the terminals of each sensor. front should be between 700-1100 ohms, and the rear should be between 1000-1600 ohms. If one is not within that range, replace it.
yes there is,,, 4-2 is the abs code for a problem with the left frt wheel sensor system.
Old Apr 27, 2006 | 04:57 AM
93acclude's Avatar
I was thinking that but I didn't have the service manual in front of me. I looked it up on the Honda Network but the information isn't as complete. The troubleshooting is the same. I would just replace the LF wheel speed sensor, its the most likely cause. Check the wiring for any damage just in case. The 10 mm that holds the sensor in place tends to break when you try and take it out so use a lot of lube and be careful. good luck.
Progen
Dec 27, 2013 02:26 AM
derickshonda
Sep 26, 2013 03:36 PM
tub_sephiroth
Oct 7, 2003 11:40 AM
ozzyman
Oct 3, 2003 12:00 PM
