I need a clutch pedal!! Help
Old Apr 26, 2006 | 11:29 AM
philkehn's Avatar
Default I need a clutch pedal!! Help
I have a 88 Honda crx dx and i purchased it with a bent clutch pedal, I cannot seem to find one for sale anywhere
Old Apr 26, 2006 | 11:40 AM
wood 1's Avatar
Default Re: I need a clutch pedal!! Help (philkehn)
Go to a salvage yard and pull one from a like model, get the whole pedal assembly.
Old Apr 26, 2006 | 10:18 PM
philkehn's Avatar
Do I absolutly need the whole assembly I am trying to stay on a budget after getting jipped from the insurance company after wrecking my tegra.
Old Apr 26, 2006 | 10:35 PM
BeavisB16's Avatar
Default Re: (philkehn)
yes, should cost you about 50 bucks at a junkyard, its a PITA to get out and put in. Remeber there is a bolt above the steering column on the other side of the air vent. It sucks. I can now take it out and put a new one back in, in an hour and a half. But i have done it a few times
Old Apr 26, 2006 | 10:49 PM
philkehn's Avatar
Default Re: (BeavisB16)
Hey thanks for the help, I never tried a forum thought i would give it a try so i will make honda-tech.com my one and only
Old Apr 26, 2006 | 11:24 PM
ED8REX's Avatar
At my local junkyard i paid 35 for my petals. but they are a pain in the behind to change. because you have to take off the petals and the junk yard and then you have to take off your own petals to replace the bent one.
Old Apr 28, 2006 | 10:33 AM
BeavisB16's Avatar
Default Re: (ED8REX)
you will need a deep socket 12mm to get to them and and extension for the one above the steering column. Did I mention to drop the steering column? Do it, its only 4 bolts or so and makes things a lot easier.
EF-Honda91
Sep 14, 2006 02:42 PM
EnSAn
Jul 16, 2006 04:33 AM
a1320addict
May 29, 2005 07:17 AM
DriveSideWays
Mar 3, 2004 06:16 AM
