ABS Light on 1993 Accord (Front/Rear Disk)
The ABS light in my 93 accord recently came on.
This was after completeling a front/rear brake job and swapping the ABS pump out.
I have checked a couple things:
1. Fluid levels
2. pressure level (seems ok)
3. Disconnected the battery to reset the computer
Is there anything I am missing? Do i need to check the grounds? if so, how do i go about doing this?
Thanks,
Jay
1. Fluid levels
Thanks,
Jay
Might check the connector plug near the caliper's. I had a similiar problem on my mom's Pontiac Grand Am. After having the tires rotated, I got home and noticed the ABS light came on. After much searching through the system, I had noticed that one of the wires had broken off at the connector near the driver side fron caliper. After soldering on a new plug, the light went away.
Hope this helps...
Hope this helps...
vtecprelude
Sep 13, 2009 12:11 PM
TWINTURBO
Mar 7, 2002 07:07 AM
