Eliminating Banjo bolts in the fuel system ... how do you do it?
Old Apr 26, 2006 | 10:03 AM
cueballsi's Avatar
Default Eliminating Banjo bolts in the fuel system ... how do you do it?
I have been searching for a while, and have found a lot of info, but I was just wondering if people can confirm what I found.
Elimination of the top Banjo bolt on fuel filter
https://honda-tech.com/zerothread?id=1452210
It says the lower hose is around a 5an size, and he converts it into a 6 an into the filter. Top of the filter is 12mm x 1.25.
NOW HERE IS THE BIG QUESTION!!!!
Is the banjo bolt on top of the fuel pump a 12mm X 1.25? Can I run an adapter from 12mm x 1.25 to 6n and then into a 5 an (assuming the hard line from the fuel pump into the fuel filter is the same size and diameter)?
Let me know ...thanks!
Modified by cueballsi at 1:35 PM 4/26/2006
Old Apr 26, 2006 | 11:36 AM
NJcoupe's Avatar
Default Re: Eliminating Banjo bolts in the fuel system ... how do you do it? (cueballsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cueballsi &raquo;</TD></TR><TR><TD CLASS="quote">
Is the banjo bolt on top of the fuel pump a 12mm X 1.25? can i run a adapter from 12mm x 1.25 to 6n and then into a 5 an (assuming the hard line from the fuel pump into the fuel filter is the same size and diameter)?
let me know ...thanks! </TD></TR></TABLE>
Since you asked nicely, and you actually know how to spell for the most part, Yes the fitting ontop of the fuel pump is a 12mm x 1.25. No need for the -5AN. Just get about 12-15ft of -6an. a Low profile 90* -6an. and 2 12mm x 1.25. So you will have -6an from the tank to the rail.
raidacaipo
Sep 12, 2008 02:31 PM
Morhpeous
May 6, 2004 04:03 PM
WayneGro
Oct 24, 2003 04:58 AM
Mikey3000
May 16, 2002 11:59 AM
Mikey3000
May 7, 2002 04:18 AM
