90 Accord LX F22 Swap
Old Apr 26, 2006 | 08:31 AM
Excelerate's Avatar
Default 90 Accord LX F22 Swap
I got a friend who has a 90 Accord LX who is trying to swap in a 95 F22 VTEC. I can't remember the exact code for that engine. To do that swap what needs to be done? Stock mounts work? Just wire in VTEC? Or is the 90 Accord OBDO? Any power steering line adjustments? Any info on this swap in general would be appreciated. Thanks.
Old Apr 26, 2006 | 12:31 PM
Excelerate's Avatar
Default Re: 90 Accord LX F22 Swap (Excelerate)
No one has done this swap?
Old Apr 26, 2006 | 12:47 PM
JDM H power's Avatar
The F22B1? SOHC Vtec?....
Old Apr 27, 2006 | 05:56 AM
Excelerate's Avatar
Default Re: (JDM H power)
Yes, the F22B1 (1995), the code escaped my mind.
Old Apr 27, 2006 | 05:59 AM
notoriousB's Avatar
Default Re: (Excelerate)
I've never done this but the mounts should be the same. You'll need to run the F22B1 ECU, I'd re-use the F22B wiring harness as well rather than trying to modify the F22A harness.
Wait, does that car even have an F22A in it? 1990? I know the 91's did...
Old Apr 27, 2006 | 08:05 AM
Excelerate's Avatar
Default Re: (notoriousB)
Yes 90-93 had a F22A1 I'm pretty sure.
Old Apr 27, 2006 | 08:18 AM
i_kick_turtles's Avatar
This is a write-up for doing a b1 headswap. It will tell you what wiring you need to run(keep your original harness) and which pins on the ecu to switch.
http://www.accordinglydone.com...=1526
Alicali
Jan 6, 2017 02:22 PM
VinceRules
Sep 10, 2012 09:00 AM
biggdogg
Jul 9, 2008 11:58 AM
jdm_accordf22a4
Sep 25, 2007 01:19 AM
DAfanatic
Jan 8, 2007 08:23 AM
