Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What are the benefits of Swepco gearbox oil?
Old Apr 26, 2006 | 07:34 AM
descartesfool's Avatar
Default What are the benefits of Swepco gearbox oil?
I have heard a few mentions recently about Swepco gearbox oil and was wondering if anyone has any info about its use in Honda gearboxes. It seems very popular in the Porsche world, but I don't know if it is a great choice for an ITR Torsen LSD. Stuff that seems to be popular is the 201:
http://www.swepcousa.com/lubesite/gear.htm
I found price here, "race-proven gear oil!":http://www.paragon-products.co...1.htm
Old Apr 26, 2006 | 08:31 AM
Andrie Hartanto's Avatar
I used to run them when I ran BMW. Lots of BMW guys and specmiata guys use them.
Their website is vagued, so I stop using them.
Old Apr 26, 2006 | 09:17 AM
.RJ's Avatar
.RJ
Default Re: (Andrie Hartanto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">Their website is vagued, so I stop using them.</TD></TR></TABLE>
The website for most products is vague - was there something about the performance of the fluids that did you not like?
With a little research I have been able to find pretty good info about almost every fluid, oil, gear oil, etc out there.
Old Apr 26, 2006 | 09:42 AM
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
The website for most products is vague - was there something about the performance of the fluids that did you not like? </TD></TR></TABLE>
It is hard to quantify or know for sure performance of the fluids. But I ran them and didn't have any problem for half a season.
Then to save some money and recommendation of people, I switched to Mobil 1 for the second half and managed to spun a rod bearing. Probably not because of the oil, but I don't know for sure.
After that I moved to Honda and used strictly redline until I see so many posts about people using Mobil 1 and switch to Mobil 1 again cause it is cheaper.
Managed to blow the K20A after 4 race weekend. No mis-shift. Is it co-incident? I like to think so. But the price of Redline suddenly doesn't look expensive anymore.
Been using redline oil for my 2nd session. I did blew one motor, but it is because of my mis shift. The other motor is 12 race weekend old and still going strong. Dynoed at 215 whp at Buttonwillow the last race. Which is similar with the dyno number on day 1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
With a little research I have been able to find pretty good info about almost every fluid, oil, gear oil, etc out there.</TD></TR></TABLE>
Information in the net is a double edged sword. Lots of good info, but there are so many bad info, second hand info or bad data. The key is to filter them out.
IMHO, if a company expect us to do the leg work doing this kind of research, they are not worth my money.
Old Apr 26, 2006 | 09:50 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">Information in the net is a double edged sword. Lots of good info, but there are so many bad info, second hand info or bad data. The key is to filter them out. </TD></TR></TABLE>
This is very true - I like to use this forum:
http://theoildrop.server101.com/ubb/ultimatebb.php
Lots of high-tech, low-bs info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">IMHO, if a company expect us to do the leg work doing this kind of research, they are not worth my money.
Thats one way to look at it, but I have had a hard time finding info from manufacturers Maybe they do not want to publish the info? But its fairly easily obtained from fluid tests - I have been using castrol synthetics (the 'euro formula') and motul in the trans and brake system and had no problems I'll be using motul in the engine when I get around to rebuilding it.
Old Apr 26, 2006 | 02:49 PM
Johnny Mac's Avatar
Default Re: What are the benefits of Swepco gearbox oil? (descartesfool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by descartesfool &raquo;</TD></TR><TR><TD CLASS="quote">I have heard a few mentions recently about Swepco gearbox oil and was wondering if anyone has any info about its use in Honda gearboxes. It seems very popular in the Porsche world, but I don't know if it is a great choice for an ITR Torsen LSD. Stuff that seems to be popular is the 201:
I found price here, "race-proven gear oil!":http://www.paragon-products.co...1.htm</TD></TR></TABLE>
The gearbox for the Robinson helicopters use Swepco, even after we surveyed all available aviation grade synthetic and non-synthetic oils. The Robinson gearbox has teletemp stickon temperature labels that show the bearing housing temperatures reach upwards of 220 to 260 degrees. To date, there have been no gearbox/bearing failures on the Robinson R22 or R44 helicopters.
Old Apr 26, 2006 | 03:19 PM
Jaker's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I have been using castrol synthetics (the 'euro formula') and motul in the trans and brake system and had no problems </TD></TR></TABLE>
Are you using Castrol SRF in the brakes? Where do you buy it, and how much do you pay?
Old Apr 26, 2006 | 04:25 PM
I use SRF in the brakes and it is great. I only bled it once all year last season.
I bought it online from proformance. around $60
Old Apr 26, 2006 | 07:04 PM
.RJ's Avatar
.RJ
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">
Are you using Castrol SRF in the brakes? Where do you buy it, and how much do you pay?</TD></TR></TABLE>
Reading ownz j00
Motul 600 in the brakes - I love it. Flush it once a year and forget about it.
Old Apr 26, 2006 | 07:52 PM
Jaker's Avatar
Default Re: (.RJ)
Reading ownz j00
Doh!
I have been using motul in the trans and brake system and had no problems </TD></TR></TABLE>
Double Doh!
Old Apr 27, 2006 | 11:13 AM
tmeracz's Avatar
Not sure that I can answer your question to the "T", but here goes:
I've run Swepco in both Honda and Porsche transmissions and it made a world of difference in both gearboxes. Shifts were smoother, grinds disappeared. Both tranny's were LSD equipped but were aftermarket helical & not clutch type like the offerings from Honda, so this may be a point to consider.
From the Porsche forums that I frequent, I've been told this about Redline gearbox synthetic from Porshce autox'ers whose opinions I trust- it is stuffed full of sulphur compounds that will cake the gearbox components with repeated exposure to high heat. It was enough to get me to consider the tear down, clean up and make the switch to Swepco in both cars. FWIW, I've been happier since.
Old Apr 27, 2006 | 11:35 AM
Default Re: What are the benefits of Swepco gearbox oil? (tmeracz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmeracz &raquo;</TD></TR><TR><TD CLASS="quote">I've run Swepco in both Honda and Porsche transmissions and it made a world of difference in both gearboxes. Shifts were smoother, grinds disappeared. Both tranny's were LSD equipped but were aftermarket helical & not clutch type like the offerings from Honda, so this may be a point to consider.
Great that is exactly the type of answer I was looking for. My dyno tuner swears by it as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Mac &raquo;</TD></TR><TR><TD CLASS="quote">
The gearbox for the Robinson helicopters use Swepco, even after we surveyed all available aviation grade synthetic and non-synthetic oils. The Robinson gearbox has teletemp stickon temperature labels that show the bearing housing temperatures reach upwards of 220 to 260 degrees. To date, there have been no gearbox/bearing failures on the Robinson R22 or R44 helicopters.</TD></TR></TABLE>
Sounds like I can't lose trying out this Swepco 201 stuff. It is going in the tranny today! (I've got a ton more ponies now in the R and I was thinking I might need a little more fluid insurance. Mobil 15W-50 is in the oil pan and cooler) Thanks.
bluesi07
Honda Civic (2006 - 2015)
Apr 30, 2007 04:39 PM
RemerLex11
Jul 6, 2005 03:17 PM
N20civicB18
Jun 7, 2005 10:27 AM
Invisible01GSR
Sep 30, 2004 09:02 PM
EF'n
Jun 17, 2002 06:55 PM
