Toda ITB kit
Old Apr 8, 2002 | 05:23 PM
S13 slide's Avatar
Default Toda ITB kit
hi, are any of you itr guys running the toda individual throttle body kit? just curious as to how you like it and how is the fuel system rigged? also what happens to all the sencors on the intake man? do you need to run a stand alone? thanks
Old Apr 8, 2002 | 05:41 PM
Big Phat R's Avatar
Default Re: Toda ITB kit (S13 slide)
It needs a dedicated ECU which is planned but not available yet from TODA.
Mucho dinero - and not worth the $$$ unless you've already done everything else you can to the motor (high comp, headwork, cams, fuel system etc...)
Old Apr 8, 2002 | 05:46 PM
S13 slide's Avatar
Default Re: Toda ITB kit (Big Phat R)
yeah im planning on building my race motor. but just doin some research. whats a dedicated ecu? is it a regular ol' ecu thats tuned to use with ITB's? or a special system? also what happens to the sencors on the intake man? thanks oh btw does any other company make ITB's? thanks
Old Apr 8, 2002 | 05:49 PM
Big Phat R's Avatar
TODA RACING Sports Injection Kit
Available for: B16A, B16B, B18C Type-R
TODA sports injection kits vastly improve engine throttle response and power output through the use of one throttle body per cylinder. Effective tuning per cylinder is not compromised as with the standard one throttle body configuration of the factory intake manifold. Price: $2,650 USD**
** Technical Note: The TODA Sports Injection kit requires a fully programmable fuel injection computer, custom engine wiring harness, and injectors.
In approximately 6 months we will release a complete kit that includes the TODA Sports Injection unit, a custom wiring harness, and ECU.
Old Apr 8, 2002 | 05:54 PM
threatcon13's Avatar
New User
those look insane! my next step after gettin headwork done maybe??
Old Apr 8, 2002 | 05:55 PM
Big Phat R's Avatar
Default Re: Toda ITB kit (ALLMOTORDC2)
Well if you have about 5K burning a hole in your pocket - go for it!
Old Apr 8, 2002 | 05:56 PM
New User
if only i did! btw...nice signature!
Old Apr 8, 2002 | 05:59 PM
lotus's Avatar
New User
They just look like Webers to me...
Had them on many cars for many years... Lots of British tuners whip off the fuel injection from modern motors and run Webers.. Very tuneable for individual cylinders, and flow VERY well thank you very much...
Too bad someone hasn't tried it on an ITR... Set of 48's with some bad *** chokes might just make some nice throttle response
Old Apr 8, 2002 | 06:04 PM
Conechaser's Avatar
Default Re: Toda ITB kit (lotus)
A friend of mine just got his TODA ITBs last week, he is still waiting on his head from portflow though, i'll have him reply to this thread when he gets online.
Old Apr 8, 2002 | 06:06 PM
Big Phat R's Avatar
Tony the Tiger ran TWM's on his B18C. That's the only one I've seen.
Old Apr 8, 2002 | 06:17 PM
lotus's Avatar
New User
Mikuni's are swell... But you have to do a lot of jet drilling and chokes are unobtainable... and I don't think the shafts are on ball bearings... I'll have to check my set to be sure..
How did they work for him? Bet they sounded great!
Old Apr 8, 2002 | 06:19 PM
Tbone's Avatar
Lip has twm's
Old Apr 8, 2002 | 06:21 PM
Big Phat R's Avatar
There is a video floating around.....
Old Apr 8, 2002 | 06:22 PM
lotus's Avatar
New User
Default Re: Toda ITB kit (Tbone)
Oops..I thought you meant twin Mikuni's.. My mistake
( try to stay in the 20th century Lotus )
Old Apr 8, 2002 | 06:27 PM
Big Phat R's Avatar
No not Mikuni's you dinosaur. These:
http://www.twminduction.com/Throttle...Body2000_1.htm
Old Apr 8, 2002 | 06:54 PM
JDM DC2 R's Avatar
Tony the Tiger doesn't have ITBs....
Old Apr 8, 2002 | 07:16 PM
Big Phat R's Avatar
Default Re: Toda ITB kit (allmotorhatch)
Then it's Lip. I guess I was wrong
Old May 4, 2002 | 07:12 PM
Cyrio's Avatar
Default Re: Toda ITB kit (Phat Bastard)
How does the car clean the air? Or is that not even an issue anymore?
Old May 4, 2002 | 07:23 PM
SuperTwinz's Avatar
my twm itbs are for sale...
Old May 4, 2002 | 07:25 PM
SEFIxCivic's Avatar
We're running the Toda ITB on one of our cars, and yes it definately requires a standalone. It's driveable on the stock ecu, but it won't pull in the upper rpm ranges and will idle around 1200. i'd look into an ECU that can caculate fuel without the map sensor, something with Alpha-N capability.
To do the fuel you'll need to change your fuel supply line to AN (via adapter), and you'll need an adjustable fuel pressure regulator (ie. SX) that runs AN fittings. you can convert the return orifice on the SX back to a barb fitting, so you can keep your stock return line.
Old May 4, 2002 | 08:00 PM
sgT's Avatar
sgT
Default Re: Toda ITB kit (SEFI8LOxCivic)
do you remember the diameter of the butterflies?
Old May 4, 2002 | 08:06 PM
SEFIxCivic's Avatar
Default Re: Toda ITB kit (sgT)
off the top of my head i can't remember, but i'll try to find out for you.
Old May 4, 2002 | 08:34 PM
roastbeef's Avatar
New User
Motec ? anyone?
Old May 5, 2002 | 04:27 PM
slowassR's Avatar
Old May 5, 2002 | 04:33 PM
STOLEN - ITR 98-0652's Avatar
If you're asking this question... are you really ready?
