crx climate control
Old Apr 26, 2006 | 06:53 AM
sanjiyan69's Avatar
Default crx climate control
are there different types of climate controls? I have seen two different kinds and I'm wondering are they interchange-able?
wayne
Old Apr 26, 2006 | 07:00 AM
G0crxG0's Avatar
USDM w/AC - Obviously tha same Climate Control in all USDM CRX's with the AC button in the lower right
USDM w/o AC - Same as above, no AC button
JDM Aircon - Has buttons in Japanese and the little **** behind the door.
EDM Aircon - Same as above only in english
Old Apr 26, 2006 | 07:01 AM
G0crxG0's Avatar
If you still need pics slet me know.
The aircon's are interchangable but to be fully functional require ALOT of RARE parts.
Other Climate Controls can be swapped in and look good, why not try a SEARCH?
Old Apr 26, 2006 | 07:07 AM
CRX Toad's Avatar
Default Re: crx climate control (sanjiyan69)
88-91 Hatch climate controls are different from the 88-91 CRX climate controls and are not easy to swap.
Old Apr 26, 2006 | 07:19 AM
G0crxG0's Avatar
Default Re: crx climate control (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">88-91 Hatch climate controls are different from the 88-91 CRX climate controls and are not easy to swap.</TD></TR></TABLE>
What if he swapped a CRX dash and AC system in?
Old Apr 26, 2006 | 07:20 AM
sanjiyan69's Avatar
I compared the crx climate control with the climate control in the civic wagon (wagon control = hatch) oh btw, I have crx control in my 89 hatch because the previous owner converted the hatch into crx interior(wiring also). however somehow the hot/cold **** is jammed and I can't turn it. In the process it also stripped the thread in the ****. Now this person has the EDM crx climte control and I want to make sure that it will work in the converted hatch so I have heat. I was driving the damn car with no heat for last 3 months in michigan and it is butt-*** cold...
thanks!
Old Apr 26, 2006 | 07:25 AM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanjiyan69 &raquo;</TD></TR><TR><TD CLASS="quote">I was driving the damn car with no heat for last 3 months in michigan and it is butt-*** cold...</TD></TR></TABLE>
Those Mid West winter's will get ya!
Try driving with no Windshield Wiper fluid to spray on your windshield.
My last CRX had no resevoir so I could only wipe (smear) the salt and grim on my windshield. Almost died about 10zillion times....
Old Apr 26, 2006 | 09:16 AM
sanjiyan69's Avatar
Default Re: crx climate control (G0crxG0)
yikes actually, my hatch does NOT have the spray nozzle...so I'll be doing the same thing :-P
Old Apr 26, 2006 | 10:18 AM
user 72830283's Avatar
yea i removed that reservoir as well...during the winter times..i devised a small bottle with a nozzle and a T-fitting at the end..and had it mounted inside the car near where my visor is...and i had the SAME thin piping used for the windshield cleaning runing outside and just taped it on top of the windshield...the door shut fine w/o restricting flow through the tube........every time i need to clean...i'd just squeeze the water bottle hard..and voila...i had my very own GHETTO "squirting" action.....
hey it WORKED...thats all i cared about and it was well worth removing that piece of **** tank...and the stupid water lines..
rcrkid
Jan 12, 2011 08:08 PM
nitewolf
Apr 11, 2008 06:18 PM
SuperRacerTypeR
Jul 29, 2006 12:15 PM
1990hondaHF
May 10, 2006 08:55 AM
bloopie
Aug 5, 2002 05:45 PM
