Crower Stage 3 cams......
Old Apr 26, 2006 | 02:43 AM
digital sol's Avatar
Default Crower Stage 3 cams......
i dont know a whole lot about these cams
will these work with a 99 jdm itr motor w/basic performance upgrades or are these a more agressive cam that requires aftermarket valve train? If it does require upgraded valve-train what upgrades would you reccomend? If i can use my stock valvetrain and keep the stock rev limit that would be ideal how-ever if necessary i could add a few things to the head
i wasnt planning on adding cams but im getting my car re-dyno'd soon w/hondata and theres a local selling some stage 3 crower cam's cheap. If they will work and be worth it then ill add the cams and some adjustable cam gear's before dyno time to make a little more power....
Old Apr 26, 2006 | 06:48 AM
Misfit's Avatar
Default Re: Crower Stage 3 cams...... (digital sol)
those cams are huge.. I wouldn't even think about using them on stock valve train.. I know I didn't.
I would not recommend using these cams. I was very disappointed with the out come when I had them and wished I could have gone back to stock.
I would recommend Hondata, and tune what you have. Stock cams are really good cams.
Old Apr 26, 2006 | 07:37 AM
Bradstard's Avatar
Default Re: Crower Stage 3 cams...... (Misfit)
You'll need a built motor to make power with those cams. I've seen them make plenty of power (264whp) but that was on a built 2.0L. There are much better cams for a stock ITR motor. If you don't want to change your valve springs I'd probably go with a set of Toda A's.
Old Apr 26, 2006 | 08:38 AM
type_r_jon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">i dont know a whole lot about these cams
will these work with a 99 jdm itr motor w/basic performance upgrades or are these a more agressive cam that requires aftermarket valve train? ..</TD></TR></TABLE>
Those cams have WAY TOO MUCH lift my friend. Your springs will touch for sure. The valve train upgrade is a must. aftermarket dual valve springs and retainers for sure rated to handle st. 3 cams. Possibly new keepers and fuel upgrades as well. Best of luck.
Old Apr 26, 2006 | 10:42 AM
Default Re: Crower Stage 3 cams...... (type_r_jon)
well if i upgraded the springs/retainers would i be able to make decent power with them?
11:1 compression and then i could add crower valve-train upgrade's
and i already have hondata and walbro 255 fuel pump
.....will they make power on 11:1 compression ?
JDogg
Honda S2000
22
Aug 25, 2010 01:09 PM
IamVtec
Jul 6, 2009 06:01 PM
The Si
Feb 22, 2007 03:17 PM
matix
Sep 29, 2004 05:10 PM
garados
May 22, 2002 06:59 PM
