is this a distirbutor problem?
this is happening more frequently now. when im driving my car and the rpms get to lets say 2500 the engine will jerk the car for a sec then its fine. sometimes it will do it again at 3000rpms. what is causing this?
Have you replaced any parts yet? Change your plugs, plug wires, cap, rotor. Just try the plugs and plug wires first. If the car isn't getting enough spark to burn the fuel, it will cause the car to "hesitate". Is this happening when you are holding at a constant speed?
i have replaced all those parts.. iv tried replacing all the cheapest parts first. this happens wile accelerating and sometimes it doesnt even do it. sometimes the car will drive exellent. most of the time it does this
damnit i always forget stuff.. its throwing code 9 cylinder position sensor.. i got a used dizzy to replace the one that come with my mpfi swap and still throws 9
iv checked wiring over and over manytimes.. i re-did the wiring twice. same stuff. how could my timing be off from doing a mpfi swap? i know the dizzy being moved could do it but could it be making my car do this and throw a code 9? i priced out a re-built dizzy today and its 380 .. id rather buy a d16 for that much .
crxjarred
10
Apr 14, 2011 01:39 PM
