car vibrates at 2000 rpm
Old Apr 25, 2006 | 04:16 PM
crx00's Avatar
Default car vibrates at 2000 rpm
Whenever the car is around 2000 rpm the car vibrates. But it doesnt vibrate much before or after that.. maybe 100 rpm in between. I have the old school hasport mounts so the car does vibrate but it never did usually at 2000 rpm. Do you guys have any suggestions on what to look at ? Thanks
Old Apr 25, 2006 | 04:28 PM
Tippyman's Avatar
Replace bushings?
Old Apr 26, 2006 | 05:30 AM
Rukusmasta2's Avatar
Default Re: (Tippyman)
so many possibilities it could be...jack up car and start shakin and see whats loose for a start...
Old Apr 26, 2006 | 06:28 AM
crx00's Avatar
Default Re: car vibrates at 2000 rpm (crx00)
up
Old Apr 26, 2006 | 07:59 AM
Its me DUB's Avatar
Mine does the exact thing at 1750. Whether it's at a stand still, in 1st, 2nd, etc. and doesn't matter of the speed. I couldn't find anyone who had the problem and/or any good ways to fix. I figured it's something like an out of balance flywheel or something in the drivetrain. Figured too much hassle for a little vibration...
Old Apr 26, 2006 | 08:20 AM
G0crxG0's Avatar
Past problem I had:
When accelerating from 2000-3500 RPMS, my engine/car would vibrate in a slight jerking motion, then once past 3500 RPMS would be fine.
What was wrong:
Valve Cover gasket. Don't know how/why, but I put on a new VC gasket, and never had the problem again.
Sounds like we had the same problem.
Old Apr 26, 2006 | 12:28 PM
crx00's Avatar
Default Re: (G0crxG0)
the strange part is there is no rpm range for the vibration .. it happens at 2000 rpm +/- 200.. it's really weird
Old Apr 26, 2006 | 01:48 PM
saikouEF8's Avatar
Default Re: (crx00)
ur bushing sound like they could be goin bad... are bushings covered by hasport? i have enjo mounts and theyre pretty stiff with my ls motor. no wheel hop whatsoever, but the vibration is around 1500-2000... no where else. in my old sohc rex the car would vibrate cuz the idle was low from oil getting in the sparkplugs.... after i fixed that it was constant. just check everything out. sounds like bushing to me... if not maybe get one of those engine dampeners?? good luck.
Old Apr 27, 2006 | 05:48 AM
crx00's Avatar
Default Re: (saikouEF8)
I figured out the problem ... the header bracket wasn't on properly because i installed a new header. so i adjusted it... vibration gone! Thanks for the help
Old Apr 27, 2006 | 10:39 AM
Its me DUB's Avatar
Default Re: (crx00)
Hmm interesting. That's probably my problem too because I have an aftermarket header and it could be hitting something. My buddy mentioned that, but I just figured since it was so specific to RPM that that couldn't be it. Good call
trigun266
Apr 23, 2011 12:31 PM
H22CL
Jan 25, 2004 12:22 PM
H22CL
Jan 25, 2004 11:28 AM
MugenizedR
Oct 29, 2003 08:27 PM
