intake swap
Old Apr 25, 2006 | 03:29 PM
Singlecam4dr's Avatar
Default intake swap HELP PLZZ
can u swap a d16y8 intake on to a d15b2 and will it hook right up other than the ecu???
Old Apr 25, 2006 | 03:32 PM
SuperHonDad's Avatar
Default Re: intake swap HELP PLZZ (Redneck_civ)
ECU?? intake?? you might be in over your head.
Old Apr 25, 2006 | 03:49 PM
Default Re: intake swap HELP PLZZ (SuperHonDad)
u think the guy im buying it from said it will fit but somtimes i dont know with him
lying or not that is
Old Apr 25, 2006 | 04:06 PM
vegaskurt's Avatar
If you have converted the b2 to mpfi then yes it will work. You just need to take the IAT off the old setup and put it somehere in the intake tube.
If you are DPFI the answer is no.
If you want to be MPFI with the Y8 intake, go for it. Its a great setup.
Old Apr 25, 2006 | 04:10 PM
Default Re: intake swap HELP PLZZ (vegaskurt)
what is mpfi (multiport fuel inge.) IAT? DPFI?
Old Apr 25, 2006 | 04:39 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redneck_civ &raquo;</TD></TR><TR><TD CLASS="quote">can u swap a d16y8 intake on to a d15b2 and will it hook right up other than the ecu??? </TD></TR></TABLE>
Wow, ecu had nothing to do w/ intake...
Old Apr 25, 2006 | 05:10 PM
vegaskurt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redneck_civ &raquo;</TD></TR><TR><TD CLASS="quote">what is mpfi (multiport fuel inge.) IAT? DPFI?</TD></TR></TABLE>
I think you need to do some reading and research regarding your d15b2 before attempting this.
Rmiller50
Honda Civic (2001 - 2005)
Jun 13, 2014 03:04 PM
Singlecam4dr
Apr 27, 2006 07:36 AM
eug_34
Nov 21, 2004 04:01 PM
