i need some help PLEASE!!!!!!!!!!!!!!
ok here is problem my throttle is sticking and i had to switch the bell housing on the tb because i have a gsr tb and be able to use my throttle cable and the spring on the tb isn'tas stiff as it was before i switch them and it will stay at a high idle unless i hit the gas pedal with the clutch in so any help woulb be great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>???????????????????????????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">???????????????????????????????</TD></TR></TABLE>
The bellhousing? Ok...
Anyway... try loosening your throttle cable a little bit. You could also try cleaning and re-greasing the spring and throttle plate where it rotates.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">The bellhousing? Ok...
Anyway... try loosening your throttle cable a little bit. You could also try cleaning and re-greasing the spring and throttle plate where it rotates.</TD></TR></TABLE>ok i don't really know the proper name for it i will try that but it just does seem to kick back when you let off the gas pedal
out_of_order
Jun 21, 2005 12:55 PM
blackc
Sep 22, 2003 05:04 PM
JCCOOL43
Jun 13, 2003 03:15 AM
