dohc zc in civic hatchback???
Old Apr 25, 2006 | 02:30 PM
notasleeper's Avatar
Default dohc zc in civic hatchback???
i am getting a civic with a stock dohc zc. its fully rebuilt with no miles. the only mods to the engine will be i/h/e. and the car will have the rear interior stripped out. and it will be lowered with springs and struts. i was just curious to what the hp number on that motor are stock, and what they would be with the bolt ons i will have. also could anyone give me an idea of what the car will run on the 1/4 mile.
thanks alot
oh and if anyone anyone could give me some other ways of getting more power, with out spending to much money, i have a very short budjet.
Old Apr 25, 2006 | 02:34 PM
crxnj's Avatar
Default Re: dohc zc in civic hatchback??? (notasleeper)
im assuming you mean the 88-91 j-spec dohc zc..its rated at around 130hp..its a good engine,,theres really not much you can do for cheap for getting more power..Maybe a nitrous oxide kit....or save some $$$$ and do a home made turbokit..
Old Apr 25, 2006 | 02:58 PM
Default Re: dohc zc in civic hatchback??? (Mr.speaker)
yeah for another 800 dollars my friend will put his turbo kit on it for me. but sadly i dont have that much money.
i heard that these motor are good for about 10psi on stock internals? and if they are properly tuned i can go as high as 15psi.
Old Apr 25, 2006 | 04:40 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notasleeper &raquo;</TD></TR><TR><TD CLASS="quote">i heard that these motor are good for about 10psi on stock internals? and if they are properly tuned i can go as high as 15psi.</TD></TR></TABLE>
15 with VERY good tuning.
You'll need prolly some upgraded internals if you go higher...
Old Apr 25, 2006 | 06:20 PM
g-ride-si's Avatar
Default Re: dohc zc in civic hatchback??? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">15 with VERY good tuning.
You'll need prolly some upgraded internals if you go higher...</TD></TR></TABLE>
on what kind of turbo?
Old Apr 25, 2006 | 06:26 PM
Tippyman's Avatar
Default Re: dohc zc in civic hatchback??? (g-ride-si)
T3 is pretty much the most common on Honda's from what I've seen.
Old Apr 26, 2006 | 04:58 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notasleeper &raquo;</TD></TR><TR><TD CLASS="quote">yeah for another 800 dollars my friend will put his turbo kit on it for me. but sadly i dont have that much money.
10-11psi is the max you can go using the stock map sensor,,,,As for the engine power I would keep it around 200-225whp with a really good tune if you want it to last some..
Old Apr 26, 2006 | 09:16 AM
SIred91's Avatar
Rainman
God, this bench racing and bench dyno **** is so annoying.
Typical for HT though I guess.
Old Apr 26, 2006 | 11:42 AM
Default Re: dohc zc in civic hatchback??? (SIred91)
what do you mean by bench racing?
i'll more then likely have to build a homemade turbo kit. sence i cant afford to buy a kit. i know how to weld so could someone give me an idea of what i will need to do this. like turbo, intercooler, bov, piping, etc.
thanks
Old Apr 26, 2006 | 11:45 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notasleeper &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by bench racing? </TD></TR></TABLE> Speculation on what a car can or can not do with or without certain modificiations.
The DOHC ZC has rods that are in comparison to the LS rods in strength, so if boosted they shouldn't be first to go. I would actually be more worried about the ringlands going poof.
BG-Teg
Mar 4, 2007 09:49 AM
contender
Feb 14, 2005 02:33 PM
DOHClessEF-9
Dec 4, 2004 02:07 PM
integracivic94
19
Nov 5, 2003 12:00 PM
allicedout
29
May 5, 2003 07:24 PM
