oily spark plugs
Old Apr 25, 2006 | 01:53 PM
juanfernandovc's Avatar
Default oily spark plugs
seal seems to be new
car running hard
spark plugs have burnt oil.
please help
91 honda accord
5 speed
Old Apr 25, 2006 | 02:29 PM
99 prelude sh's Avatar
Default Re: oily spark plugs (juanfernandovc)
Prolly need new valve cover gasket's. Not a hard fix...
Old Apr 25, 2006 | 02:52 PM
cats_on_ice's Avatar
Default Re: oily spark plugs (99 prelude sh)
^^^^^ What he said.
This is like a half hour job. Get a valve cover gasket kit from honda, but just make sure that you bolt head back on to 7 ft lbs.
Old Apr 25, 2006 | 03:07 PM
d112crzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanfernandovc &raquo;</TD></TR><TR><TD CLASS="quote">seal seems to be new
car running hard
please help
91 honda accord
5 speed</TD></TR></TABLE>
which seal? lower or upper? the only way to change out the lower seals is to take off your whole cam/rocker assembly. its not as hard as it sounds tho. I'm sure that once those are replaced properly, your problem will go away.
just because someone replaced the top ones, that doesnt stop it from leaking.
Old Apr 25, 2006 | 03:36 PM
BLKFLSH's Avatar
First, is the oil above the nut part, or below it? Wire side, or spark side?
Old Apr 26, 2006 | 03:43 AM
standbackimapro's Avatar
its not the valve cover specifically,
Its the spark Plug tube seals
Old Apr 26, 2006 | 07:37 AM
92ehatch's Avatar
Default Re: (standbackimapro)
op please search, this has been asked probably 50 times in the last month, there are 3 writeups that are constantly posted on here about it and im tired of finding them and posting them up.
if the oil is ABOVE the spark plugs that is. You need to replace the lower spark plug tube seals, which involves taking out the rocker arm assembly to replace them
get a valve cover gasket kit from advance, its less than 20 bucks.
Chavy340
Oct 3, 2011 12:22 PM
preludebro
May 1, 2011 09:39 AM
LAO
Dec 19, 2007 08:55 AM
grlstockb18c1
Jun 11, 2003 06:32 PM
wales78
Jul 9, 2002 10:33 AM
