Suspension & Brakes Theory, alignment, spring rates....
Just got an alignment...FYI
Old Apr 25, 2006 | 01:50 PM
Understeer's Avatar
Default Just got an alignment...FYI
I drive a 2001 Integra with GC/Koni (400#,500#) with 205/50/15 Azenis and 15x7 Kosei K1 wheels. Previously I had -2.5° front camber and -1.4° rear camber. The wheels were tucking a bit, and was rubbing the fenderliner under hard cornering.
There was also not enough suspension travel and the shocks were hitting the bumpstops. So I decided to raise the vehicle up about 1" or so. My new alignment readings are below.
Camber
FL: -1.7°
FR: -1.8°
LR: -1.20°
RR: -1.0°
Toe settings are exactly 0 on all 4 corners and thrust angle is 0.0°
Caster is 0.3° and 0.4°
If you're curious, the ride height is 12.50" front and 12.75" rear from the center wheel hub up to the fender. This lowers the vehicle 1.5" from OEM height.
Overall I'm happy with the numbers for a street driven car and occasional autocross in STS.
Modified by Understeer at 3:29 PM 4/25/2006
Old Apr 25, 2006 | 01:58 PM
MattD@Stoptech's Avatar
Default Re: Just got an alignment...FYI (Understeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">
Camber
FL: -1.7°
FR: -1.8°
LR: -1.20°
RR: 1.0°
I hope you just missed a "-" in there otherwise the car is going to feel funny in left-hand turns.
Old Apr 25, 2006 | 02:29 PM
Understeer's Avatar
Default Re: Just got an alignment...FYI (El Pollo Diablo)
Typos! I've fixed it.
Old Apr 25, 2006 | 05:55 PM
chrisw85's Avatar
what are you runing for a rear anti-roll bar with those spring rates?
Old Apr 25, 2006 | 06:10 PM
Understeer's Avatar
Default Re: (chrisw85)
22mm oem itr bar with bsq kit.
Old Apr 25, 2006 | 09:43 PM
Understeer's Avatar
Default Re: Just got an alignment...FYI (aallbbeerrtttttt)
No camber kit, I just lower/raise to gain/lose camber.
How "slammed" are you going to be? You won't need a camber kit, but the car won't handle very well..
commguy
Suspension & Brakes
Aug 9, 2007 04:10 PM
DJThomas1189
Suspension & Brakes
Feb 23, 2007 05:54 PM
msinsky14
Sep 18, 2006 12:57 AM
FalkenSiR
Suspension & Brakes
Jun 6, 2006 11:06 AM
2000GSR
Oct 21, 2003 08:53 AM
