will 90 ef fenders fit on 90 crx
Im assuming you mean civic fenders onto a crx..
they will fit and bolt up but then the crx front bumper wont fit right and the hatch fenders arent made for the crx lower panels....
No, you will have to have the civic front bumper to make it fit. They are a direct bolt on, but will not fit very nice without modification/cutting of the fender/bumper below the corner light. The civic and crx are practically the same, just the fender and front bumper are slightly different.
But you can make the civic front end fit a crx, but no mix/matching parts. the headlights are the same, corner lenses are different. I think the hood is the same, so if you want to use civic fenders, then you need a civic front bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">But you can make the civic front end fit a crx, but no mix/matching parts. the headlights are the same, corner lenses are different. I think the hood is the same, so if you want to use civic fenders, then you need a civic front bumper.
problem is the side lower portion of the fenders,,they wont match different cars..crx has lower panels,,and flat sides,,,,,,civic has no lower trim and has contours in the fenders to match the rest of the body.....
</TD></TR></TABLE>problem is the side lower portion of the fenders,,they wont match different cars..crx has lower panels,,and flat sides,,,,,,civic has no lower trim and has contours in the fenders to match the rest of the body.....
Ef4doorwagon
Feb 16, 2014 12:33 AM
SolAssassin
Paint and Body
Aug 2, 2007 11:26 PM
rags2riches
Oct 17, 2003 08:00 PM
