Old Mar 25, 2015, 12:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
installing an HID kit on a 03 Honda accord
Old Apr 25, 2006 | 10:45 AM
Accone's Avatar
Default installing an HID kit on a 03 Honda accord
I own a 03 Honda accord I was wondering what is the easiest way to install an HID kit? because just to replace the light bulb is a big hassle. Wow how do I miss my 99 Accord it was so easy to chnage it on those accords
Old Apr 25, 2006 | 11:56 AM
kbanks45's Avatar
Default Re: installing an HID kit on a 03 Honda accord (Accone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accone &raquo;</TD></TR><TR><TD CLASS="quote">I own a 03 Honda accord I was wondering what is the easiest way to install an HID kit? because just to replace the light bulb is a big hassle. Wow how do I miss my 99 Accord it was so easy to chnage it on those accords </TD></TR></TABLE>
Well, most guys on this site will tell you to get a retro fit housing on both sides, but this is what I did. On the passenger side, I just reached around up in there. I mounted the ballast on frame in the front, almost over the headlight housing. It's between the grill and the housing, but on the inside. Connect your bulb then connect the wiring. Now on the driver side, you must remove the battery, and a small plastic piece that's attached to the frame. I mounted the ballast on side where the battery goes. You will still be able to put the battery back in , just look at it before drilling. I used self tapping screws to mount both ballast. After installing both bulbs and ballast, and connected all wiring, get on level ground. (This is very important) Have a friend or somebody park their car in front of yours about 2 to 3
car lengths. aim your lights at bumper level, If you don't you will blind the hell out of people, because of the glare. At bumper height, you will light up the ground and keep your beams under the back window. At night have someone drive your car behind you to see if it's done right. This is what I did and I have know problem, and best of all, no complaints from people getting blinded. Now if your willing to spend some money, you can get a retro fit housing. That's what most guys get on this site. GOOD LUCK!!!!
Old Apr 25, 2006 | 01:27 PM
Accone's Avatar
Default Re: installing an HID kit on a 03 Honda accord (kbanks45)
thanks
Old Apr 25, 2006 | 05:10 PM
msedacca's Avatar
gen7accord.com
More than DIY on there, along with how to black house them. Also there is more than 1 DIY at accordtuner.com, suggest you go there.
Joycesensation
Jun 27, 2013 10:29 AM
XenonDepot
10
Nov 17, 2010 05:05 AM
delsoldriva
Lighting
Mar 15, 2009 03:51 PM
xlilsharkyx
Lighting
Jul 31, 2008 11:31 AM
Ruskimafia
Feb 12, 2006 08:39 AM
