Axle instal tips?
ok im putting my stock d16 in my crx and all i need to do is put the axles in. ok i got the passanger sid ein no problem. but on the driver side i cant get the hub to move out of the way. it was soo easy on the passanger side. any tips to get it to budge. i mean its only the bottom bolt correct? teh one like right below the brake rotor?
-Kyle
-Kyle
Line it up and get someone on the other side to hold the axle straight while you jam it in. takes me about two tries while under the car holding the middle of the axle and pushing in.
Some people say if you put the little snap ring opening on the bottom it helps a bit but I never had any issues. When I had problems it was because I wasn't putting it in straight.
i dont think i will have a problme with the axle itself. its more along the lines of getting the damn hub to move. the bolt that pokes out the bottom wont come out the top. its very irritating
-Kyle
-Kyle
Disconnect the lower ball joint and push the rotor aside. No problem.
To do this, jack the lower control arm up and stick a breaker bar in the gap between the ball join and the lower arm. Then slowly lower the jack and the joint will serparate. Some people use a socket to do this but I've had much better luck using the handle end of my breaker bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H4 Project »</TD></TR><TR><TD CLASS="quote">i dont think i will have a problme with the axle itself. its more along the lines of getting the damn hub to move. the bolt that pokes out the bottom wont come out the top. its very irritating
-Kyle</TD></TR></TABLE>ball joint bolt??? if so pry on it or something it will come out...eat some wheaties I have faith in ya haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 »</TD></TR><TR><TD CLASS="quote">ball joint bolt??? if so pry on it or something it will come out...eat some wheaties I have faith in ya haha
</TD></TR></TABLE> YAY someone has faith in me. LMAO!
ya that was a good link. thanx for it. i found out to just hit it. HAHAHAHAHA! well it should be done tomaro. thanx guys. all i need is a battery and to get a seat bracket. haha
-Kyle
-Kyle
drjondurst
55
Feb 13, 2003 09:38 AM
