h22 tune now oil leak
Honda-Tech Titanium Member
I had my 92 Accord h22 swap tuned the other day and the car is running alot better, but there's an oil leak. It seems to be coming from the bottom of the block on the drivers side and it's leaking quite a bit. Any ideas as what it could be? Head Gasket? Oil pump? Thanks
You can replace the seal around the crank, yes part of the oil pump but if you do a search on here I believe there is instructions on how to replace the seal without removing to many parts.
wtsapexipowerfc
11
May 28, 2011 04:47 AM
