88-91 Civic/CRX Si cam on newer civic?
Old Apr 8, 2002 | 01:38 PM
ion_four's Avatar
Default 88-91 Civic/CRX Si cam on newer civic?
So, I bought a Gude cam from this guy and he told me it was for the 92-95 SOHC VTEC, but it turns out it's for the 88-91 1.6l in the Civic/CRX Si and I suppose the EX, as well...Will it work on the 92-95 1.5l non-VTEC? I'm going to sell this, since I can't use it. I'll be putting it in the classified section, but here are the specs in case the valve lift makes a difference for the engines on which it will work.
262F2416 PART NO.: HCCS09 (GORILLA JR.)
DESCRIPTION: Special cam for NOS! Requires Bullfrog
2724NOS ECU.
POWER BAND: 5000 R.P.M. to 8600 R.P.M.
IDLE: (Fair)
SPECIFICATIONS: Intake LIFT - 0.428 DURATION - 242 Exhaust LIFT - 0.421 DURATION - 258
Old Apr 8, 2002 | 06:49 PM
ion_four's Avatar
Default Re: 88-91 Civic/CRX Si cam on newer civic? (ion_four)
So, anyone know for sure if all D-series SOHC non-VTEC engines can use the same camshafts? Anyone?
Old Apr 9, 2002 | 04:15 AM
Mista Bone's Avatar
D Tranny Guru
it will work in the 88-91 16v motors and 92-95 DX 1.5L motors. It will require a cam gear to correct the 1/2 tooth difference when used in a 1.5L.
Old Apr 9, 2002 | 05:30 PM
ion_four's Avatar
Default Re: 88-91 Civic/CRX Si cam on newer civic? (Mista Bone)
1/2 tooth difference? How is it not an integer value? One tooth/two rotations?
Thanks though!
Old Apr 10, 2002 | 03:10 AM
Mista Bone's Avatar
D Tranny Guru
on a 1.5L the cam centerline is closer to the crank centerline.
x425sTyleZx
Jan 21, 2007 11:34 AM
94eg4
Feb 19, 2004 06:16 AM
ppavis
Dec 31, 2003 11:21 AM
ion_four
Jun 4, 2002 09:04 PM
