electrical problem?
Old Apr 24, 2006 | 07:05 PM
StRacer's Avatar
Default electrical problem?
I just bought a 91 civic 4dr and my interior dash lights don't work and lighter does not work. I check all fuses and they are fine(ones under the dash and under the hood). THe light has both connections on the back of it. I have no idea what else to check.
Old Apr 24, 2006 | 08:27 PM
statik121's Avatar
Default Re: electrical problem? (StRacer)
Did you check to see if the bulbs are burned out? Have seen that a few times.
Old Apr 24, 2006 | 11:34 PM
YasRex's Avatar
Get out a multimeter and check to see if the plug is getting power. If its not go back and find the problem. A helms/haynes manual helps--buy one
Old Apr 25, 2006 | 04:32 AM
StRacer's Avatar
Default Re: electrical problem? (statik121@hotmail.com)
I find it hard for all the lights to be out and light not to work also.
Old Apr 25, 2006 | 05:02 AM
wood 1's Avatar
Check your dimmer switch, it could be bad. Check to see if you have power to the lighter, the lighter element may be bad.
Old Apr 25, 2006 | 09:20 AM
StRacer's Avatar
Default Re: electrical problem? (wood 1)
Dimmer works, cause all the dash and heater lights dim when I adjust the switch. Just the cluster lights behind illuminate the gas, radiator temp, and gas guage works. The light that shows what gear its in (auto) and seatbelt lights work.
Old Apr 25, 2006 | 09:40 AM
wood 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StRacer &raquo;</TD></TR><TR><TD CLASS="quote">Dimmer works, cause all the dash and heater lights dim when I adjust the switch. Just the cluster lights behind illuminate the gas, radiator temp, and gas guage works. The light that shows what gear its in (auto) and seatbelt lights work.</TD></TR></TABLE>
Do you mean lights behind gauges DON'T work? check for power at the plugs on the back of the cluster. Red wire is power to them when lights are on, Red/Black is the ground, you may have a broken wire somewhere. I doubt all the bulbs are blown, but they could be.
Old Apr 25, 2006 | 10:19 AM
StRacer's Avatar
yes, behind guages only.
Old Apr 26, 2006 | 04:47 AM
StRacer's Avatar
Funny thing is all the sudden last night it started working, guages lights that is. I still have no clue on the lighter.
Old Apr 27, 2006 | 04:54 AM
StRacer's Avatar
Look at this ****, now they quit working again. Is there a relay that just controls the lights behind the guages. Like state the little green square around the gears on the dash and seatbelt light still work.
bambam530
Oct 27, 2013 07:12 PM
Mr Marcin
Jul 14, 2008 09:13 AM
PHOBIA
24
Oct 4, 2006 11:39 AM
miamijdmcoupe524
10
Oct 23, 2005 01:02 PM
