Rear toe adjustment?
Old Apr 24, 2006 | 06:52 PM
j spec's Avatar
Default Rear toe adjustment?
ok just had a full allingment done and for some reason the toe is out on my passenger side rear. the adjustment arm is all the way in. also on the driver side the arm is about in the middle but the toe on that side is fine. its a 95cx hatch and my rear disks are off a 93 si. just wandering if i just need to buy a adjustable toe arm or should i check something else first. just wandering if anyone has had a similar problem. thanks
Old Apr 24, 2006 | 08:37 PM
Smash03's Avatar
Default Re: Rear toe adjustment? (roma's GSReg6)
Hmmm...Ion't think the rear toe can be adjusted.
Old Apr 24, 2006 | 09:53 PM
suspendedHatch's Avatar
Default Re: Rear toe adjustment? (Smash03)
Sorry, Smash03, I don't know you personally, but I don't know why the expletive you bothered posting such an idiotic, ignorant statement. Of course the rear toe is adjustable!!! What the expletive?!
Your parts are bent. Hopefully you can take the parts back to the junkyard and exchange them.
Old Apr 24, 2006 | 11:47 PM
Smash03's Avatar
Default Re: Rear toe adjustment? (suspendedHatch)
Yea I know you can replace them if they are bent, but what I'm tryin to say is that it is not adjustable itself. You get at where I'm sayin. I'm not tryna argue or whatever wif you either, but replacing and adjusting are two different things.
Old Apr 26, 2006 | 12:38 AM
I dont know how to say this more clearly. The rear toe is adjustable. There are compensator arms with a sliding mounting point. There is a spec that it is supposed to fall within. If it's at the far end of adjustment, and still out of spec, you have bent suspension components.
Old Apr 28, 2006 | 08:56 PM
postman's Avatar
rear toe is not adjustable on all vehicles. maybe on this one, but not all by far
EF8DayDreamer
Suspension & Brakes
Mar 26, 2012 02:32 AM
PRoJecTSLeePaLoT
Mar 22, 2007 10:35 AM
j spec
Suspension & Brakes
Apr 26, 2006 08:52 PM
j spec
Apr 25, 2006 04:17 PM
