rear toe adjustment question
ok just had a full allingment done and for some reason the toe is out on my passenger side rear. the adjustment arm is all the way in. also on the driver side the arm is about in the middle but the toe on that side is fine. its a 95cx hatch and my rear disks are off a 93 si. just wandering if i just need to buy a adjustable toe arm or should i check something else first. just wandering if anyone has had a similar problem. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">Sounds like the '93 discs may have been in an accident. I didn't know you had toe adjustments in the back.</TD></TR></TABLE>
sure do...they are where the front of the trailing arm meets the body of the car.
and i agree with you about them being possibly bent.
