installing 1990 - 1991 driver side window
Old Apr 24, 2006 | 05:24 PM
Aquafina_Powered's Avatar
Default installing 1990 - 1991 driver side window
Ok, i can't get this window inside of the actual door. I don't want to break the glass (again). The seat belt part is in the way.
Can anyone give me any tips? What all has to be off?
Old Apr 24, 2006 | 11:46 PM
YasRex's Avatar
Default Re: installing 1990 - 1991 driver side window (Aquafina_Powered)
You've got to take the inside part off and it just goes right in there. Take the time to remove the parts you need to remove
Old Apr 25, 2006 | 11:59 AM
what do you mean 'inside' part? I have the door panel and most of the seat belt assembly off.
Old Apr 25, 2006 | 12:12 PM
EL Vap133's Avatar
What I did was tilt it in sideways, then adjusted it straight so that I could bolt it to the mechanism.
Old Apr 25, 2006 | 12:13 PM
baastard's Avatar
i've done it before its not to hard.. just make sure u have the window cranked all the way down theres holes in the bottom of the door panel that matchs where u gotta screw in the bolts for the window to the control arm
Old Apr 25, 2006 | 03:25 PM
SuperHonDad's Avatar
Default Re: installing 1990 - 1991 driver side window (baastard)
The 2 bolts are 10mm and when you roll the window down to a certain point they line right up. In and out in less than 10 min.
Old Apr 25, 2006 | 03:29 PM
cbp_crx's Avatar
Default Re: installing 1990 - 1991 driver side window (SuperHonDad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">What I did was tilt it in sideways, then adjusted it straight so that I could bolt it to the mechanism.</TD></TR></TABLE> thats what i did and went right in
hondaslave1342
Feb 6, 2019 04:07 PM
VTECwalka
Apr 25, 2013 06:26 AM
Blaze45
Sep 17, 2005 07:57 PM
CivicBoi
Jun 18, 2003 02:02 PM
XEF-9X
Feb 19, 2003 05:20 AM
