b16 vs. b18 opinions
Old Apr 24, 2006 | 04:36 PM
athbaseball23's Avatar
Default b16 vs. b18 opinions
what would be my better choice a b16a or b18c?
(i did search and i know there are a couple other of the pretty much same thread but i didnt quiet get everything i wanted from them when i looked at them.)
Old Apr 24, 2006 | 04:51 PM
B.'s Avatar
B.
400 HP Club
Default Re: b16 vs. b18 opinions (athbaseball23)
i would go with the b18c, but i like my b16a2 aswell.......
Old Apr 24, 2006 | 04:53 PM
FLoSSnJERKS's Avatar
Default Re: b16 vs. b18 opinions (B.)
sold my b16a to get a b18c nice change
Old Apr 24, 2006 | 06:27 PM
mar778c's Avatar
Community Builder
Community Influencer
b18c > b16a
Old Apr 24, 2006 | 07:58 PM
Ruben19's Avatar
b18c
way better motor than the b16a
you will feel more torque
Old Apr 24, 2006 | 08:19 PM
SiB16A's Avatar
Default Re: (Ruben19)
there is no replacement for displacement 1.8>1.6 all day.
boost could be replacement for displacement though, but since you posted in a all motor thread, then 1.8 !!!!
Im assuming your talkin about GSR & B16
Modified by SiB16A at 10:05 PM 4/24/2006
Old Apr 24, 2006 | 08:52 PM
quicksilver1689's Avatar
i ♥ snails
you didnt specify which b18? b16 over a b18b.
B18c1 holds aplace in my heart.
Old Apr 25, 2006 | 07:13 AM
Default Re: (quicksilver1689)
yea i was talking bout the b18c1
Old Apr 25, 2006 | 10:51 AM
BryanPendleton's Avatar
Is this purely a long block comparison? If so, then the obvious choice is shoot for the larger displacement.
If you are considing a full swap, I highly considering the B16. The gearing in the B16 will easily overcome the power deficit between a b16 and b18c1. You can build up a B18 shortblock to swap later. But similarly, you could swap a B18c1 and swap tranny later, but in my experience people are less inclined to spend money on the tranny, even when it will boost acceleration considerably more than gobs of other motor modifications. Its all a fine line which every you choose, but ultimately I think sharing your goals and use would help your recommendations.
Old Apr 25, 2006 | 02:17 PM
Default Re: b16 vs. b18 opinions (BryanPendleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton &raquo;</TD></TR><TR><TD CLASS="quote">Is this purely a long block comparison? If so, then the obvious choice is shoot for the larger displacement.
im talking abaout the whole swap. I am just planing on putting the engine in for right now and put a couple of bolt ons on it and have it as my daily driver. In the future i plan on getting a couple of other upgrades to the engine but i am keeping it NA.
Old Apr 25, 2006 | 02:37 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (SiB16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A &raquo;</TD></TR><TR><TD CLASS="quote">there is no replacement for displacement 1.8&gt;1.6 all day</TD></TR></TABLE>
Went from a b16 to a b18 very happy with this upgrade.
Old Apr 25, 2006 | 02:55 PM
D-Rob's Avatar
Default Re: (***-assin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin &raquo;</TD></TR><TR><TD CLASS="quote">
I'll second that.
Old Apr 25, 2006 | 03:06 PM
jdmride's Avatar
Default Re: (D-Rob)
B18C1 GSR or B18C5 ITR All the way 87mm the crank 81mm bore
And if you whant to do LS VTEC or B20VTEC
Get a B18A/B 81mm bore Short block or a B20B/Z Short Block the B20B is a 2.0L 84mm bore the b20b and b18b have the same Crank 89mm
Dont whats you Time and Money on a B16A 1.6L whast of time and it does not make that much power all motor i seen 190 to 210 Whp very hard to make power all motor
Roy
Old Apr 26, 2006 | 03:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athbaseball23 &raquo;</TD></TR><TR><TD CLASS="quote">
im talking abaout the whole swap. I am just planing on putting the engine in for right now and put a couple of bolt ons on it and have it as my daily driver. In the future i plan on getting a couple of other upgrades to the engine but i am keeping it NA.</TD></TR></TABLE>
I maybe reading into your comments a little too much, but it certainly sounds like you are trying to keep things simple and modest and reliable, and wil rely on bolt-ons for the most part, with perhaps some head or/and valvetrain in the distant future. Are you paying someone for the swap labor, or are you DIYer?
If you are paying someone for swap and money doesn't grow on tree for you, I would seriously choose the B16. Sure you won't have the bragging rights of pimping a B18 GSR, but you will be beating their butt on the street, thanks to your shorter gear ratios and shorter final drive. There is a good article explaining transmission gearing by Bense:
https://honda-tech.com/zero...46134
Old Apr 26, 2006 | 06:50 AM
so if i were too strap on a b16 tranny onto a b18c1 would that be even better? and why do some people do the opposite, putting a gsr tranny on a b16?
Modified by athbaseball23 at 8:19 AM 4/26/2006
Old Apr 26, 2006 | 08:54 AM
Walterronny's Avatar
more displacement = more torque..
i like both (i have B16) but if i can to have a B18 , i would have it..
Old Apr 26, 2006 | 09:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athbaseball23 &raquo;</TD></TR><TR><TD CLASS="quote">so if i were too strap on a b16 tranny onto a b18c1 would that be even better? and why do some people do the opposite, putting a gsr tranny on a b16?
Modified by athbaseball23 at 8:19 AM 4/26/2006</TD></TR></TABLE>
You take a B16 tranny and a B18c1 long block and you have the best of both swaps.
People will swap taller GSR gears for high power applications (ie turbo), as this helps traction loss and can improve 1/4mile times by better spacing of shift points and keeping them out of 5th gear. Some just swap in 5th gear for low rpm highway cruising.
Old Apr 26, 2006 | 09:13 AM
Twilight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Walterronny &raquo;</TD></TR><TR><TD CLASS="quote">more displacement = more torque..
i like both (i have B16) but if i can to have a B18 , i would have it..</TD></TR></TABLE>
I'd say it like this; More displacement = more torque = is more power. Thatswhy i choosed B18.
Old Apr 26, 2006 | 09:43 AM
Ass$nyper's Avatar
Default Re: b16 vs. b18 opinions (Twilight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight &raquo;</TD></TR><TR><TD CLASS="quote">
I'd say it like this; More displacement = more torque = is more power. Thatswhy i choosed B18. </TD></TR></TABLE>
thats why I also upgraded from a 1.8 to a 5.7
Old Apr 26, 2006 | 10:05 AM
[QUOTE=BryanPendleton]
QUOTE]
so if i can get that you would say definitely do that? But if, and say im putting it in and want the best motor with just a few bolt ons(i/h/e, im, cams, cam gears) then what engine would do me the best?
Old Apr 26, 2006 | 10:30 AM
black_EM1's Avatar
Community Builder
You do realize the final drive is the same, correct?
Old Apr 26, 2006 | 11:36 AM
Default Re: b16 vs. b18 opinions (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
You do realize the final drive is the same, correct?</TD></TR></TABLE>
Opps my bad, getting mixed up with the LS Tranny. That is correct, FD's are same.
Old Apr 26, 2006 | 06:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athbaseball23 &raquo;</TD></TR><TR><TD CLASS="quote">so if i can get that you would say definitely do that? But if, and say im putting it in and want the best motor with just a few bolt ons(i/h/e, im, cams, cam gears) then what engine would do me the best?</TD></TR></TABLE>
Old Apr 27, 2006 | 04:17 AM
First there is no "BEST" motor. "Best" should be banned from use on all auto boards. Now if you want the motor/engine with the most potential for power (between the B16 and B18c1) then everyone else has answered your question. B18c1
Old Apr 27, 2006 | 06:23 AM
Twilight's Avatar
thats why I also upgraded from a 1.8 to a 5.7 </TD></TR></TABLE>
I, and maybe you forgotted one thing, Rpm. Because torque x rpm= power.
