tein pillow ball mounts question
OK guys I can't seem to know what I am missing in my pillow ball mounts but look the gap between the nut and upper plate please help asap thanks
Modified by yz125rider21 at 10:59 PM 4/24/2006
There should be a washer thats part of the strut. It slides on the shaft of the strut until it hits that lip. Thats the only thing I can think of. It would make the pillow sit on it and make it sit higher.
You are missing nothing, it's suppose to have a gap there. It's the space for the rubber bushing that gets smashed between the shock tower and shock. You can see the small black rubber bushings from the engine bay, under you bolt on the shock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">You are missing nothing, it's suppose to have a gap there. It's the space for the rubber bushing that gets smashed between the shock tower and shock. You can see the small black rubber bushings from the engine bay, under you bolt on the shock.
nono I talking about above the upper plate read it a few time haha...not talking between the spring and plate...look above that and the see the gap between the nut and plate!
</TD></TR></TABLE>nono I talking about above the upper plate read it a few time haha...not talking between the spring and plate...look above that and the see the gap between the nut and plate!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 »</TD></TR><TR><TD CLASS="quote">nono I talking about above the upper plate read it a few time haha...not talking between the spring and plate...look above that and the see the gap between the nut and plate!</TD></TR></TABLE>
That's what I'm talking about, when you install any suspension, stock or aftermarket, there are 2 small black bushings. Ok, when you install your pillow mount, you put one bushing directly on the strut, then when you install the strut the top part where the bolt is comes through the strut tower. After the strut is installed properly, you put the other small black bushing on before the final bolt goes on the strut, and is smashed down with a washer.
If this does'nt help, then I'll get a pic to show you. Also have installed struts before on a ef? Because if so, you will know what I'm talking about. Also if your coilovers are new, then tein sent you a piece of paper that shows for correct order for stuff to be installed.
Hope all of this helps, again if you don't understand I'll post a pic.
This is not Tein but Apexi. Same deal though. Mine came with several washers as shown in photo. They are there depending on the spring length that you are running. You change the number of washers depending on the spring length to balance out the coilover length, otherwise the longer the spring, the less adjustment that is possible overall in the coilover collars at the bottom of the unit. (Hope my explanation makes sense.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1C9R9X1 »</TD></TR><TR><TD CLASS="quote">yup , 2 bushing ,metal 2 metal = noise, and vibration
No I'm talking a about the 2 rubber bushing that are stock, no metal too metal contact.
</TD></TR></TABLE> No I'm talking a about the 2 rubber bushing that are stock, no metal too metal contact.
I talk to Paul at Tein and he saw my problem so I have to order diff collars cause the strut rod is diff between the tein ss and the tein ss with pillow mount option....so i be ordering them at closest tein dealer around here...thanks for help guys....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">Also, why did'nt you ask this question in the supension forum? You would of had 3 times the help on this question.
I was fustrated lol and wasnt thinking but good tip mate thanks
</TD></TR></TABLE>I was fustrated lol and wasnt thinking but good tip mate thanks
