bad TPS??
I have and obd0 b16 swapped into my rex and when i'm at a stop light and i take it outta gear my rpm sometimes stays at 1.5 until i lightly pull on the gas pedal and then it drops down to where it should be. Is this a problem with my throttle positioning sensor or is my throttle cable too tight (because it doesnt happen all the time). Could it also be a problem with the IACV? Thanks a lot
From: Close to West Chester, PA, United States of America
Seems pretty simple... there is a spring that pulls the acceleration pedal back out... it could either be off, or just weak... get down there and check it out... my 90dx with 178k did that... I just played with the spring (and used my foot a few times) to pull it back out and all was well.
pull up on the gas pedal if it goes down. to tight of a cable. if not then a vacuum leak. possibly tps but doubt it unless your throttle is real touchy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenix_iii »</TD></TR><TR><TD CLASS="quote">Seems pretty simple... there is a spring that pulls the acceleration pedal back out... it could either be off, or just weak... get down there and check it out... my 90dx with 178k did that... I just played with the spring (and used my foot a few times) to pull it back out and all was well.</TD></TR></TABLE>
Mine did the same thing. Just the pedal...
CimorelliCRX
Sep 8, 2002 09:57 PM
