Help with rear t bracket.
For the rear t bracket does it matter if its manual or automatic?? cause I was going to get a automatic rear bracket and someone told me I needed the manual bracket to fit and the automatic wont fit. Its from a 94 teg. Its going to be a b16a2 into a 93 eg. any advice or help will be nice. Thanks
As long as I dont have to take out any more Metal Gears
I would imagine that one from an auto tranny would be different from a manual one. Try searching first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug »</TD></TR><TR><TD CLASS="quote">Dont get it of the Teg. I hear the only one that works is off the 99-00 Si which is the one I used. But i believe that you might be able to use the 93-97 Del Sol B16 </TD></TR></TABLE>
Do some more research.
ONLY use a rear t-bracket from a 1994-2001 5-speed Integra. LS/RS/GS/GSR/TYPE R, it doesnt matter.
The B16 ones are too short for the eg chassis. You would use that one in a 1996+ civic.
JDM_CAM
Feb 5, 2012 07:48 AM
allmotor.net
Aug 6, 2003 04:41 AM
