Does it matter what oil pan i use on my LsVtec?
I am in the last stages of finishing up my LsVtec. I am wondering does it matter which oil pan i use, or can i use any B series pan?
Did you use some sort of a block girdle? If yes, you'll need the correct windage tray, oil pick up and pan...
Most of the time, if you use a girdle, you'd need a GSR tray, pickup and pan.
If no, LS pan is that which you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93-lsvtec-eh2 »</TD></TR><TR><TD CLASS="quote">whatever pan you use you need to use the same pickup. if you use a ls pan you need a ls pickup and etc.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">alright thanks
</TD></TR></TABLE> If you plan on using any header thats not designed for an Integra LS, you need to use a P72 Oil pan. There are clearance issues if trying to use a header such as a JDM 4-1.
