Problems after clutch swap
Old Apr 24, 2006 | 02:01 PM
4runner's Avatar
Default Problems after clutch swap
Ever since the clutch change, when i engage the clutch on 1st gear and release slowly, it sounds//feel the clutch like its dropping when engaging, but I'm not dropping the clutch...I also have a lag between accelleration and decelleration when in gear (lettin foot off gas pedal or steppin on the pedal), like when i downshift, i feel the clutch engage, then there's a lag to the tires responsing and when im about to gas, there's a lag response..I also get grinds on the gears that ive never grinded on before. At first i thought it was cuz of my front mount cuz it was ripped, but i poly'd it but that still doesnt help, now im guessing its cuz of my axles, my axles feel loose when i shooked it under the car.
any help is appreciated.
Old Apr 25, 2006 | 02:04 AM
4runner's Avatar
Default Re: Problems after clutch swap (88HaveFun)
help meh :D
Old Apr 25, 2006 | 03:13 AM
YasRex's Avatar
oh my god
Old Apr 25, 2006 | 07:42 AM
91civichatch's Avatar
Did you torque the bolts down to factory spec? I changed out my clutch once and just zipped them back in with the air gun. About a month later I started to get a wobble and alot of clutch chatter when i would let the clutch out slowly.
Old Apr 25, 2006 | 09:19 PM
4runner's Avatar
Default Re: (91civichatch)
yea torque'd the bolts down. There's no noise coming from the clutch, its just that it feels like im "droppin" the clutch everytime i engage into a gear. Other than that, its the axels makin the noise, im changing them soon hopefully :D
Old Apr 25, 2006 | 09:33 PM
statik121's Avatar
Did you adjust your cable accordingly? It is a new clutch. Also, sounds like the clutch is not fully disengaing, that may account for the grinding. That would be the mainshaft and countershaft not syncronizing.
Old Apr 25, 2006 | 09:42 PM
charlee's Avatar
if its a cable tranny make sure that your clutch cable adjuster is adjusted properly.pull the cable up while while you adjust the nut.if its a hydro , you might wanna bleed the clutch lines.my last thought is the you proly didnt install the clutch properly.but if you followed proper instructions on how to put a clutch or youre sure you did it right then try bleeding it or adjusting it or bleed the clutch like i said. hoped this worked for you man.
Old Apr 26, 2006 | 05:16 AM
4runner's Avatar
Default Re: Problems after clutch swap (charlee ricer)
yea its cable. I have it adjusted to grab early-mid. The clutch that I put in isn't new, it was from a z6 Worst comes to worst, I'll redo everything, but do you guys think the axle has any effect to any of this? My axles feel F'd up
appreciate the help
Old Apr 26, 2006 | 05:41 AM
YasRex's Avatar
Used clutch + the flywheel that didnt come with it = the problem youre having
Old Apr 26, 2006 | 05:48 AM
h224thgensedan's Avatar
is your car an 88 or 89? If so the clutch disk size changed from i think its 210 mm in 88-89 up to 212 in 90-91 that might be whats causing your problem
Old Apr 26, 2006 | 01:31 PM
charlee's Avatar
i really dont know if the fact that your axles are a litle loose could create a problem.mine you can shake them just a bit and i was feakin out. i asked my friend and he said its allright.
Old Apr 27, 2006 | 12:13 AM
4runner's Avatar
could it be the mix-matchin of the flywheel and clutch that causes this problem??
cuz im using z6 clutch with 90-91si flywheel but i dont think any of that would matter right? i thought they were interchangable but i could be wrong
and for the splines, i checked them before i put them in, im using the 89-91 tranny.
EDIT: well i did some searching and found 2 threads; 1 thread said cable and hydro clutches arent interchangeable, and the other thread said it is interchangable 92-00 as long as you use the same pressure plate with the clutch...
im using my old pressure plate with the z6 clutch, im not sure whether the problem is im not using the z6 PP or the hydro clutches don't work with cable trannys
can someone clear this up
Street Racer X
Sep 21, 2008 02:35 PM
dazuk
Mar 2, 2006 11:52 AM
delpoop!
12
Jul 16, 2003 07:51 PM
erikgsr
Oct 26, 2002 04:42 AM
LOwrestling2001
May 26, 2002 03:28 AM
