*Brand New-Never Ran* LS-Vtec w/Receipts F/S
Old Apr 24, 2006 | 11:36 AM
Spec...G@rage's Avatar
Default *Brand New* LS-Vtec w/Receipts F/S ITR Parts F/S
LS-VTEC
Hows it going guys? I finally decided to join as a member after about a year of using Honda-Tech. I have a brand new, ZERO MILES, LS Vtec for sale. Here is a list of what its got:
-Blueprinted Block
-Balanced Rotating Assembly
-Bored and Honed Block w/Deck Plates
-Stage 1 Port and Polish
-Endyn 81.5mm Roller Wave Pistions
-Eagle LS Rods
-Endyn Valve Springs
-Crower Titanium Retainers
-H.O.P Main Bearings
-H.O.P Rod Bearings
-H.O.P Type R LMAs
-H.O.P Type R Valves
-H.O.P Oil Pump
-H.O.P Water Pump
-H.O.P Timing Belt P72
-H.O.P Timing Belt Tensioner Pully
-H.O.P Headgasket
-H.O.P Oil Filter
Oversized LS-Vtec a/n oil fittings
ARP Headstuds
Machined and Balanced Lightwheight Crank Pully
P28 ECU w/ Hondata (Tuned for Skunk2 Cams and 310cc Injectors)
GSR Cams In Head As Of Now:
OBDII to OBDI Conversion Harness
All Brand New OEM Harware throughout the Block/Head
This Engine was built and completely assembled by Payne Technologies. I have all receipts for engine work/assembly. Totals over $4000.00
I have pictures upon request. You can contact me @ 315-396-4420 EST (Justin)
If somone could post the pictures for me that would be great because I am not able to do so.
Looking For $4000 or B/O
Also have a set of brand new ITR Rods and Pistons. Make an Offer
Thanks in advance,
Justin
New York
Modified by 1QcKCrX at 5:26 PM 4/24/2006
Modified by 1QcKCrX at 11:53 AM 4/25/2006
Old Apr 25, 2006 | 10:54 AM
Default Re: *Brand New* LS-Vtec w/Receipts F/S ITR Parts F/S (1QcKCrX)
Bump
Old Apr 25, 2006 | 04:58 PM
Bump...
Shane_00integra
Sep 19, 2012 01:44 PM
90efhatch
May 12, 2011 06:26 AM
Your Name
Nov 4, 2008 10:35 AM
str8sleepr
May 2, 2006 06:26 PM
synergy004
Jan 29, 2003 10:14 PM
