I have oil leaking from my axel...
A couple of days ago i noticed that i have trany fluid leaking from my passenger side axel, i think that it is coming from where the trany meets the axel is this a hard job to fix i would like to fix this a.s.a.p.
thanks
thanks
Bad Axle Seal. Requires removing that axle, pulling the seal out, putting new one in, replacing axle. To remove the axle you can either remove it completely or detach the wheel hub from the lowerball joint and swing the hub assembly to the rear of the car after popping the axle out of the transmission (In other words you don't have to remove the Axle/Spindle Nut -- which is a bitch to remove)
Good luck. Not a very hard job for a newbie.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC »</TD></TR><TR><TD CLASS="quote">Bad Axle Seal. Requires removing that axle, pulling the seal out, putting new one in, replacing axle. To remove the axle you can either remove it completely or detach the wheel hub from the lowerball joint and swing the hub assembly to the rear of the car after popping the axle out of the transmission (In other words you don't have to remove the Axle/Spindle Nut -- which is a bitch to remove)
Good luck. Not a very hard job for a newbie.</TD></TR></TABLE>
Agreed
Agreed
Pochtecatl
Jul 11, 2004 11:43 AM
