need smog on b16 swap ..........so cal area
Old Apr 24, 2006 | 10:13 AM
EK79's Avatar
Default need smog on b16 swap ..........so cal area
i need to smog my car and i dont think it will pass i have all the necessary sensors plugged in but i do have the obd2-obd1 harness in and i know that wont fly ....i tried my stock ecu and it threw several codes who do you guys get your cars to pass and can you lead me in the right direction need it done soon i will try to get another extension if possible
in san diego
Old Apr 24, 2006 | 10:37 AM
EK79's Avatar
Default Re: need smog on b16 swap ..........so cal area (stoopid monkey)
bump
Old Apr 24, 2006 | 11:07 AM
fmrprojects's Avatar
what yr is the car? if its a 99-00 then use the b16 ecu and wire the neccessary sensors to get it smogged. obd-2 is a liitle harder cause they hook up a scanner at the smog station. and another thing is when you plug in the ecu , you have to drive it a certain distance before all the monitors in the ecu have run. or else when you go to the smog station they will fail you.
Old Apr 24, 2006 | 11:23 AM
EK79's Avatar
its a 96-98 civic dx hatchback im looking for a way to smog the swap i know it will pass i have everything hooked up just a little worried it might not it runs fine and i have all the carb legal parts but the motor is jdm
Old Apr 24, 2006 | 11:53 AM
db8gsr_teg's Avatar
your not gonna pass smog with a b16 unless you get it BAR. My advice is you find someone who will do it under the table for you or put the stock motor back in.
Old Apr 24, 2006 | 12:09 PM
EK79's Avatar
Default Re: (db8gsr_teg)
if i still had the stock motor
you know any one?
Old Apr 25, 2006 | 01:36 PM
Jedi_Sol's Avatar
Default Re: (stoopid monkey)
If the car is running fine and you say you have all the sensors hooked up, why not get it BAR'd? If you fail BAR, they will tell you exactly what you need to pass.
If you are worried about registration, you can pay your fee without proof of smog (I learned the hard way). But you will evenutally have to send it in later. In the mean time, you can get your car BAR'd.
Don't worry if your car is JDM, JDM motors can pass.
Old May 2, 2006 | 12:56 PM
EK79's Avatar
Default Re: (Jedi_Sol)
yeah i know but i have obd2-obd1 conversion and thats not smog legal dont they hook up the car to the obd reader or something like that?
Old May 2, 2006 | 01:26 PM
turbo99's Avatar
Dang, bro. I'm going through a similar problem with smog. I have an ls in a 99 civic turbo. I'm going to have to take the turbo off and get it BARd. That's my only option. You should do it too. But, to answer your question, buy an OBD2a->OB2b wiring harness and plug in a 99 Civic SI ecu (I have one handy by the way). That should do the trick. You can buy the harness here:
http://rywire.com/store/index.php?cPath=35
You should be able to get your car BARd like that. Good luck and wish me luck too.
Old May 3, 2006 | 06:54 AM
EK79's Avatar
Default Re: (turbo99)
what do you want for it and are you sure this will work i have found a place to do it but its costly
Old May 10, 2006 | 07:45 AM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo99 &raquo;</TD></TR><TR><TD CLASS="quote">Dang, bro. I'm going through a similar problem with smog. I have an ls in a 99 civic turbo. I'm going to have to take the turbo off and get it BARd....
No, that isn't your only option.....
Old May 10, 2006 | 11:59 AM
turbo99's Avatar
Default Re: (hazw8st)
So what's my other option? The turbo kit is made for a civic SI, not Integra. The carb EO number says it's for a 99 Civic SI. I don't even want to try; the ref might say something that the kit is not for an LS. I already took the turbo kit off so I'm going to take it to the ref, bone stock. At least that way, if I ever get pulled over, I have my BAR sticker.
Old May 10, 2006 | 12:05 PM
TEST ONLY's Avatar
CARB turbo placard, and leave it alone. You don't need a BAR sticker. PM me for more info...
lazyxmofo
Northern California (Sales)
May 11, 2008 12:24 PM
olddohc
Nov 20, 2002 01:48 PM
rexnoir
Jul 18, 2001 07:18 AM
