d61a6 basically same as d61a1
i currently have a 91 crx si with a d16a6 engine and am buying a motor from an integra that is a d16a1, are these motors basically the same? im basically just using the d16a6 engine for spare parts. i may have the engine code wrong but thats as close as i remember i know the crx engine ends in 6 and the integra ends in a 1.
thanks
stephen
thanks
stephen
The D16A6 is SOHC, and the D16A1 is the DOHC engine from the 1986-1989 Integra. The two engines are actually quite different. And a D16A1 will not bolt into a 1991 CRX without alot of work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">The D16A6 is SOHC, and the D16A1 is the DOHC engine from the 1986-1989 Integra. The two engines are actually quite different. And a D16A1 will not bolt into a 1991 CRX without alot of work.</TD></TR></TABLE>
(I was just typing the same thing)
well i guess a screwed myself up then. ended up buying an engine i can not use. i wasnt planing on making a swap, just spare parts. but i guess i messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched »</TD></TR><TR><TD CLASS="quote">well i guess a screwed myself up then. ended up buying an engine i can not use. i wasnt planing on making a swap, just spare parts. but i guess i messed up.</TD></TR></TABLE>
Pretty much, there's not much on the motor, if anything, that is interchangeable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">take the pistons from the A1, and put them in your A6. thats about it. </TD></TR></TABLE>
will this make a diferance? will this engine fit in an accord?
will this engine fit in an accord?</TD></TR></TABLE>
no, it will fit the 86-89 Integra and 86-87 Civic
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched »</TD></TR><TR><TD CLASS="quote">crap. so i really screwed myself up on this one... well i guess i will have to re-sell this engine...</TD></TR></TABLE>How much will you take for it? How many miles on it, what condition is it in, and what does it come with?
IS300ruler
Dec 1, 2003 11:25 AM
