Honda S2000 Honda S2000
lug NUTs ********************************
Old Apr 24, 2006 | 12:45 AM
WowOzYouRock's Avatar
Default lug NUTs ********************************
on stock Honda/Acura wheels and on stock Honda/Acura lug nuts, this is spherical shaped (also called ball shaped or acorn shaped)... on most aftermarket wheels, this is conical shaped (tapered), NOT ball shaped.
example of oem type:
^^^ thats what i need but open end
now my question is where to get open end ball shaped or acorn shaped lug nuts for oem NSX rims? i need to have open end cuz im using extended studs ...
another question ... what would be the ideal tire size for 2002 nsx rims to fit onto my slammed s2000?
Old Apr 24, 2006 | 12:49 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: lug NUTs ******************************** (FR-MOB #4: Jerk)
Open ended OEM lugs huh? I'll try a search after this post. Not too sure that I'd find anything. Thinking "switch studs".
225/255, considering offset and alignment is ideal.
Old Apr 24, 2006 | 05:54 AM
Nishant's Avatar
Default Re: lug NUTs ******************************** (FR-MOB: Projekt)
autozone sells some, i don't think you want those
Old Apr 24, 2006 | 06:25 AM
Francesco's Avatar
man i have no idea. im posting to see if you get an answer because i would like to know myself.
so your going with nsx rims?
Old Apr 24, 2006 | 06:32 AM
prelude222s's Avatar
i think u can knock off the ends on those..but it might rust..
just a thought
Old Apr 24, 2006 | 06:33 AM
Francesco's Avatar
Default Re: lug NUTs ******************************** (prelude222s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude222s &raquo;</TD></TR><TR><TD CLASS="quote">i think u can knock off the ends on those..but it might rust..
just a thought </TD></TR></TABLE>
im sure drilling out the lugs wouldn't be safe
Old Apr 24, 2006 | 06:45 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
correct!!! we've done that many times..... if not try summit or jegs
Old Apr 24, 2006 | 06:47 AM
Nishant's Avatar
Default Re: lug NUTs ******************************** (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
im sure drilling out the lugs wouldn't be safe </TD></TR></TABLE>
if you use a dremel and then powder coat, it would work but will look fugly
Old Apr 24, 2006 | 07:14 AM
S CARTER's Avatar
Default Re: lug NUTs ******************************** (Nishant)
Hey i do honda parts and im pretty sure i have what your talking about.
Its an open ended acorn style lug nut. When i go home for lunch ill take a pic and post it but if your near a honda dealership the part # is 90381-SV1-901.
Old Apr 24, 2006 | 08:34 AM
S CARTER's Avatar
Old Apr 24, 2006 | 08:48 AM
Default Re: lug NUTs ******************************** (S CARTER)
nicee.. thanx S CARTER ... youre my hero ROFL
for real, thanx though ... i didnt know honda sells them
Old Apr 24, 2006 | 08:58 AM
Nishant's Avatar
what care do those belong to?
Old Apr 24, 2006 | 09:07 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S CARTER &raquo;</TD></TR><TR><TD CLASS="quote">Hey i do honda parts and im pretty sure i have what your talking about.
good info
Old Apr 24, 2006 | 09:28 AM
SOL1D's Avatar
I remember those style of oem lug nuts being on a accord 90-93 accord?....or older prelude. For some reason i remember those being on my friends 90-93 accord, but im not sure if they were there originally.
Old Apr 24, 2006 | 10:45 AM
JDM knowledge's Avatar
Default Re: lug NUTs ******************************** (SOL1D)
those are a bit shorter than the regular ones. Will this effect anything compared to aftermarket ones made for extended studs? I need some as well i hate my J's Racing ones.
Old Apr 24, 2006 | 10:47 AM
* B A N N E D *
Default Re: lug NUTs ******************************** (JDM knowledge)
Gorilla makes them.
Old Apr 24, 2006 | 11:06 AM
ej0513's Avatar
the open end Acorn style came on the Del Sol S i think, i know for sure it was on the Del Sol thoughl.
Old Apr 24, 2006 | 11:15 AM
S CARTER's Avatar
Default Re: (ej0513)
Yeah its pretty much any honda that has an over sized wheel cap that covers
the lug nuts such as older accords odys delsol's with the fat five spoke wheels etc...
Old Apr 24, 2006 | 11:17 AM
S CARTER's Avatar
If u have any problem gettin them let me know and ill send u 20 of them for like 16 bucks shipped.
Old Apr 24, 2006 | 11:54 AM
S CARTER, whats your paypal? send me 25 pcs ...
and 3 OEM honda S2000 oil filters
pm me how much shipped
Old Apr 24, 2006 | 12:22 PM
fknfast's Avatar
gorilla sells them too
Old Apr 24, 2006 | 12:30 PM
* B A N N E D *
Default Re: lug NUTs ******************************** (fknfast)
You're late man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Gorilla makes them.</TD></TR></TABLE>
Old Apr 24, 2006 | 12:32 PM
Dang showed me the gorrila last night ... they are more tapered than acorn to me .. id rather get the oem honda one ...
thank you guys for the inputs
and Bill just inform me that my J's intake just came in yay lol
Old Apr 24, 2006 | 12:34 PM
* B A N N E D *
I'll pick it up from Bulletproof and test it out for you!
Old Apr 24, 2006 | 12:42 PM
its already in his house foo!!
ohh i need metal valve stems too!!!
rays valve stem looks raw but oem honda one will do ...
S CARTER were are you?
fknfast, do you have those things i need instock?
and i need it by friday!!! ( hahah sounds like qoute from fast and the furious) lol
