Humming noise????
Hey guys, my car has a weird humming noise, I have bad toe camber wear on my 2 front tires since my car is lowered, its on the inside of the wheels, tires are bald on the inside bad.
Anyway, on turns on the highway i get these humming noises, you feel alot of the road.. im thinking its my tires??
Also.. when im goin straight i can feel and hear the hum, but if i flinch my steering wheel to the right just a tad bit it goes away.. wtf?
It cant be my wheel bearings, i get no knocking, or play at all.. is this my powersteering shitting out?
Modified by dc2r01 at 12:28 AM 4/24/2006
Just went out and cruised, it makes the noise, but when the flcik the streerin to the right it goes away... hmm, im gonna try and put my rear tire in the front tommorow.
Also did circles with steering wheel locked, no clickn, any noises, at all. smooth
maybe its just the bad tires up fropnt
Well, start by getting an alignment. Then think about unslamming the car. A slammed car looks good but handles bad. Until your ITR was slammed it was the best handling FWD production car in the world. Now its crap.
If you are driving and it hums but goes away when you jerk the wheel to the RIGHT than it's the LEFT wheel bearing. If you jerk it to the LEFT and it makes the noise its the RIGHT wheel bearing. They have to be pressed in. No big deal just dis-assemble and if you do not have access to a press than bring it to any mechanis shop and they can swap it out for you. Hope that helps.
