98 honda accord lx over heating
Old Apr 23, 2006 | 09:44 PM
edcpus's Avatar
Default 98 honda accord lx over heating
hello everyone, i have a 98 honda accord lx 5 speed, i have a problem hopefully someone can help me solve it. my car over heats when im driving and lets say i get up to 3000 rpm, the temp gauge rises, it rises where i have to pull over and let it cool off. However, i have replaced the thermostat, from honda, the temp sensors, hoses, is it possible that the radiator could be bad, because the lower radiator hose sucks in if im sitting there at idle. But when the car is just sitting in run spot, i ran it for a hour and the a/c was on it never ran hot. the temp gauge never moved. can someone please help me, this problem has been going on for months.
Old Apr 23, 2006 | 10:24 PM
YeuEmMaiMai's Avatar
Default Re: 98 honda accord lx over heating (edcpus)
it appears that it is time for you to replace your lower hose and flush your rad out.... The lower rad hose is reinforced since it is on the suction side of the water pump and since the hose is collapsing, it is restricting flow.
Also you may want to pressure test your car to make sure that you did not blow a head gasket from it running hot like that........
Old Apr 23, 2006 | 10:37 PM
sonnieeeeboi's Avatar
because the AC was on, the fans were on, thus keeping the engine at normal temperatures. Is there air in the system?
Old Apr 25, 2006 | 03:51 PM
edcpus's Avatar
Default Re: (sonnieeeeboi)
well the lower radiator hose, i have replace just the other day, but the suction was still there. I believe it is the radiator, i have one on order, but we will see what happens
summertimehonda
Jul 11, 2012 01:32 PM
kevinp1
Jun 30, 2012 06:47 PM
edcpus
Jul 21, 2011 07:24 AM
McGruber
Jul 25, 2010 12:33 PM
Elvis1977
Mar 26, 2004 11:45 AM
